Hi there.
The 5532 should have a microphone as it has a webcam in it. If not there is a microphone jack at the left side of it.
If you want to test your microphone there is an application called sound recorder. It is located in Start - all programs - accessories.
You can change the properties for the microphone if you right click on your speaker icon at the bottom right of your task bar (bottom right of the screen) and click on recording devices. This is assuming your computer has Windows 7 which I think it does. In this screen it will show all connected devices you can use for recording.
A recording application you can try is called Audacity. You will need to google it. It is a music recording program that is free. It isn't the easiest to use though. If you want to record live music you can use the sound recorder to record it as well.
If you have any other questions leave a comment and I can get back to you.
Yes it has a microphone.I think it is in the side of the camera.
old PCs this was an option, newer PCs is it built in and 5532 is not a full model name, at all
so there is no answer
if using windows are you, learn to use the microphone test, in control panel sound
its there
or load skype and test the mic first before wording where it is,
most folks buy a quality USB mic, and the be amazed at the sound. go broke at $15.
inside mics all stink, we know that.
acer.com go there find your unstated full model see manual , PDF and read it , it does cover SOUND.
RTM
if confused read the manual first and read the service tag on PC to find the real model
Acer PureZone (only for certain models)
in your manual it says that, clear as day.
and sub models do exits even not the same world wide, and no country told by you wow.
turn the PC upside down
the black acer tag on the left
shows 5432 series, (I this is only a series not a real model)
next line down shows. MODEL # KOWBO or the like this is it true PC name, only this, and only this and the SNID show what options it had new, and for what country.
first try it , then if fail ask, for help and Easter egg hunts are not fun, lacking model number of PC>
do not ask where it is. with you fearing to dismantle any PC. and looking your self.
some have the 2 mic option, others not. all are inside hiding from you and show up as a 1/16" 1mm hole. or pair.
where it is does not matter but is for sure facing you with lid open, it is for using say SKYPE.
or making a voice MP3.
it is not for recording any concerts or the like. the mics are horrible here, voice only and tinny sounding
buy a real mic and use it. vast exist for sure USB
it is inside
one model has 2 mic, other 1.
no model told, by you. 5532-xyz123, , zyz123 not told and maters.
answer is yes,
any mic on earth working can record any sounds you want. birds or acid /metal rock or what. not.
acer.com
read your manual there on sounds and recording
it is there to read, at any time free of charge.
inside and yes.
RTM your PC has manual to read at Acer.com I see it there and all that is covered there.
for sure. just read it. then if confused ask related question and at the point of confusion.
