Question about Brother DCP 165C Compact Color Inkjet Multifunction Printer
Error 36 - Brother DCP 165C Compact Color Inkjet Multifunction Printer
Posted by salamandala on
pctech33
    Novelist:
  • 256 Answers
The error message 36 may happen to come in your Brother printer due to some physical damages. Thus, you can solve the issue by replacing these damaged parts of the printer. You need to replace the maintenance unit with a new one. It is good to upgrade the carriage PCB, head or carriage unit and carriage motor, if these are causing the issue. The main PCB of the printer may also get the issue and you need to replace the main PCB. You may also need to replace the power supply PCB if it is damaged.
Posted on Sep 20, 2011
Getting error code 36 hour duration
I appreciate your inquiry, friend!
Based off what you have described your Frigidaire freezer is displaying an error code of 36 hours. Normally it will display that once power has been restored, it is indicating that the freezer has been without power for 36 hours. Hold the "alarm reset" for 3 seconds and that should help clear out the code. I hope this is helpful. -Matt
Mar 10, 2015 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
What does code 36 mean
Error code 36 does not show in Rheem tankless manuals.
Copy following link for general troubleshoot and error codes, and Rheem contact information:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Error code 36 does not show in any resource, including 2008 service manual, or 2012 product manual.
Check that remote control display is illustrating the correct number.
For example there is error code 35.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 19, 2012 | Rheem Paloma Tankless Water Heaters...
My Sub-Zero is flashing error code 36. What is this?
Diarmait --
Technical Service Manual for the SubZero 600 series can be downloaded at:
[https://docstore.fedex.com/subzero]
Username=subzero
Password=subzero
Write back if you still need help.
-- SWT
Aug 23, 2010 | Sub-Zero 650 / O Bottom Freezer...
Give me solutation of errore 36 came inb DCP165C Brother Printer
That error 36 - means "Head/carriage unit travel error" , if the printer is still under warranty, have it serviced. But if its out of warranty try to find any obstacles on the travel path of the head/carriage unit. If you cant find anything, it only means you need to replace some parts.
1. carriage PCB
2. head/carriage unit
3. CR encoder strip
4. carriage motor
5. main PCB
6. power supply PCB
7. maintenance unit
May 13, 2010 | Brother DCP 165C Compact Color Inkjet...
Error code 36 when transferring photos to harddrive
According to Microsoft, error 36 is:
"ERROR_SHARING_BUFFER_EXCEEDED
36 (0x24) - Too many files opened for sharing."
There may be many causes for this. Do a virus scan and run the registry repair tool from this download link:
http://www.windows-error-repair.org/tools/regcuredownload.php
Run the tool, press the scan button and let the tool clean and fix your registry.
Good Luck!
Apr 05, 2010 | LaCie Computers & Internet
Error message on my printer that says unable to print 36
If this is a Brother clean the clear strip on the carriage assy. it is a timing strip for the carriage , I have seen ink on these cause the "36" code
Jun 05, 2009 | Office Equipment & Supplies
MacBook Error 36
Error 36 means “I/O error” (input/output error) and does not explain what the cause of the problem is, sorry.
Check your Mac for bad blocks you can use Disk Utility.
Aug 11, 2008 | Apple MacBook Mac Notebook
Brother DCP 165C Compact Color Inkjet Multifunction Printer Logo
1,338 people viewed this question
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Ed
Ed
