Televison & Video Logo
Posted on Sep 13, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Auto tune will only get channel 9 an their digital channels go and gem
Henry Thomas
Level 3:
Genius:
  • Master 1,074 Answers
  • Posted on Sep 13, 2011
Henry  Thomas
Master
Level 3:
Genius:
Answers
1074
Questions
Helped
336690
Points
2402
Please clarify your question in more datail then repost before you can help.thanks
Will this model receive 7flix and other new channels? If not can we get a set box to get them
if your tv is already receiving digital stations the it will receive 7 flix
If you are already using a set top box it will get 7 flix and all the channel 9 station as well
all you have to do is use the remote to get the on screen menu up, (press the menu button) --navigate around until you get the auto tune in channel selection auto or manual---select auto tune and let it go and all the extra channels will be programmed in
1helpful
Hi Reprogrammed my TV and GEM has come up in a small screen. Went into aspect but did not help. Other channels are fine. Anje
try using menu button to get the onscreen menu again and allow the auto tune to do the job
it could be a glitch or the way you tried to get the channel
1helpful
Help I have sound on the new 7fix channel but no picture all it says is invalid format. What does this mean.
go to the onscreen menu and allow the auto tune to do the job
there are also extra channel 9 channels and the one auto tune will bring all channels
1helpful
2answers
I just received a Coby TFTV992 9" portable TV. I'm trying to tune the TV channels without success.
1st click the "mode" button on the TV or remote then use the vol. up and down buttons to scroll around until you get to DTV mode then press "enter" on the remote you should get a message "please run channel auto scan" . click "Menu" on the remote the "Picture" screen will come up, keep clicking the vol. up button to scroll past "Audio" then "Setup" then to "Channel" then use the CH up or down buttons to scroll to "Air" click OK , then use the CH down button to scroll to "Scan all channels" then click the vol. up button. it then should start scanning, FYI you have to be fast!
My lg tv does NOT have sound for Gem channel... All the rest are fine except for gem!! How can this be fixed?
Try re-tuning the channels, the original auto tune might not have picked up the correct frequencies.
How do i tune the channels on a toshiba rc3910
Hi
Before tuning the set to auto tune mode, make sure the antenna or cable, whatever may, connected to its appropriate sockets at the back of the set firmly. To make it autotune:
As new services are broadcast, it will be necessary to
re-tune the television in order to view them.
Auto Tuning will completely re-tune the television
and can be used to update the channel list. It is
recommended that Auto Tuning is run periodically to
ensure that all new services are added. All current
channels and settings, i.e. locked channels, will be
lost.
[1] Select the SETUP from the main menu by using
Up or Down buttons. Press OK and Setup menu
will be displayed.
[2] Select the Installation from the Setup menu
by using Up or Down buttons. Press OK and
Installation menu will be displayed.
]3] Select Automatic Channel Scan from the Installation
menu by using Up or Down buttons and press OK.
A screen will appear warning that previous digital
programmes and settings will be deleted. Select Yes
and press OK to continue with the Auto tuning.
The television will start to search for all available
stations.You must allow the television to complete
the search. When the search is complete the Auto
tuning screen will display the total number of
services found.
* After search is completed for digital channels, a
message asking whether to search for analogue
channels appears on the screen
** Press the OK button to search for analogue
channels. The following menu appears on the screen
for analogue channel search
OK.
I just bought a teac HDB849 set top box and when I do the automatic channel search I only get 9 digital, GO and Gem. No other channels are found. when I manually key in 72 for 7two or any others I get...
I find that with my HDB849 I have to be very carefull with the positioning of the aerial/rabbit ears to get all the channels to (ABC, 7, 9, 10, SBS and their sub cahnnels) to recieve them at all. Also once you get all the channels it is prone to digitization or pixilation at times due to bad weather/very overcast days.
Try the Teac.com.au for a firmware upgrade as this also solved not being able to view avis & images, listen to mp3's etc.
Overall the majority of reviews say the HDB849 is to be avoided.
Once set up correctly through trial and error and an absolute shitload of patience and re-tuning it seems to operate fine. Just pray you do not get a power outage or you have to start all over again.
Last point, try the teac 1300 number in Australia (or relevent country) and harras them for info whilst trying to stay calm and nice with the unlucky "tech support" person
1helpful
2answers
Philips Magnavox TP2784C TV always powers up to Channel 9
Unplug unit from AC outlet for 10 - mins then plug back in to AC. Turn unit on select channel 3 turn off and back on.
2answers
68helpful
Comcast Remote requires 3 digits be entered to change channels
l. Push the "Menu button"
2. Push the "Menu button" again
3. Scroll to "Setup" and push "OK"
4. Scroll to "Guide setup" and push "OK"
5. Scroll to"No Auto Tune"
6. Click on arrow next to "No Auto Tune". This will change it to "Auto Tune".
7. Now exit, or just punch in any channel number.
You should now be able to go directly to a channel without entering zeros.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
