Samsung SyncMaster 940MW 19" LCD Monitor Logo
Question about Samsung SyncMaster 940MW 19" LCD Monitor
I have a SyncMaster 940NW +nvidia 8800gts graphic card, with the default driver that windows 7 came with , i got 1440x900 resolution(native) , but after i update with ANY driver from nvidia i lose my native resolution, and i cant figure it out , i had windows 7 six months ago , and worked fine even after update with the latest graphic card driver(same graphic card same monitor as now )
Posted by andrei on
richie46
    Top Expert:
  • Samsung Master
  • 12,962 Answers
Right click on desk top and get the menu for changing screen resolution.
Posted on Aug 21, 2017
5 Related Answers
Anonymous
SOURCE: Hannspree 19" Widescreen resolution available
I have the same problem. i downloaded a generic driver that allows 1600 X 900 resolution. this is better..things are taller rather than wider (with the 1280X1024 resolution). i dont understand why there isnt a 1440X900 driver available for XP systems.
Posted on Jul 31, 2008
Anonymous
SOURCE: LCD monitor not working in native resolution after osd reset
TRY RE-INSTALLING ALL THE DRIVERS FOR IT AS MAY JUST BE COMMON FUALT IN THEM
Posted on Jan 19, 2009
Anonymous
  • 585 Answers
SOURCE: No 1440X900 Resolution Option in Display Settings
Windoze is not detecting the monitor correctly. Right click the desktop as you had before to get to the display settings. Click the "advanced" button at the lower right, on the next window, click the "Monitor" tab, and remove the check from the box from "Hide modes that this monitor cannot display". That should add to the settings the 1400 X 900 resolution you are looking for.
Posted on Jan 24, 2009
Anonymous
  • 2923 Answers
SOURCE: monitor resolution
What do you mean that you were unable to get the native resolution of 1440x900? Are you saying that the resolution varries?
Since you mentioned that the mother board supports 1440x900, try to set the monitor resolution to that same resolution and then restart the computer.
If you will get the same problem, you have to make sure that the video card supports 1440x900 resolution.
Posted on Apr 15, 2009
frankzjm
Frank Zhang
  • 191 Answers
SOURCE: Samsung 244t Monitor display issue
if the monitor will match well with Nvidia GTS8800 graphic card, you need to consider two issue:
1) resolution match from windows display property and moniter manu same one.
2) refresh frequency match from windows display property-->advance-->monitor and monitor manu--> refresh frequency
if two side setting could be all matched that you can use normally
if two side setting could not be matched any above step that you can not use some resolution normally possible.
hope help you something fixed, please take a rating let me know how much helped you thanks! keep in touch your question
Posted on May 29, 2009
1helpful
I can't get the native resolution in Win7 (just reinstalled the SO). I want a 16:9 resolution, but I0m stuck in 4:3...Thanks.
Hello hayawata
You need to install the drivers for you graphics card.
Go through my published guide entitled, How to install Graphics Drivers, Nvidia and AMD Radeon!!!
Then once you has successfully downloaded and installed the video driver you will then need to go through another short informative guide entitled How to set your Desktop Screen Resolution?
There that should get you to run at the 16:9 resolution!
Thanking you very much!
damnor01
1helpful
I have installed Windows 7 in my Pc with the monitor Sync Master 920 NW and the maximum resolution available 1280 X 768 when the max resolution of the monitor is 1440 x 1024.
Download the correct graphics driver.
If you have a Graphics card, download the driver from either Nvidia or ATI.
If your graphics chip is on the motherboard, download the driver from your manufacturers support page
1helpful
Screen resolution problems since installing latest drivers.
try to revert back to your old nvidia driver, if it works, the latest driver does not support your syncmaster, contact nvidia or samsung..
Windows XP Not displaying fully on 1440x900 resolution.
If you have one of those older CRT monitors you should be able to resize the image. Some LCDs have screen shifting tools too. Try doing a full restart, too. (shutting your computer down, waiting 1 or 2 minutes, then starting it up again.)
1helpful
Resolution problem in Windows 7
Windows 7 official release is in Oct. The Windows 7 version you have is probably the Release Candidate version, this is the last Beta version before its offical release. This version does not have drivers for al lot of devices and if you cannot get the driver from ATI at this stage then you have to wait until it becomes available.
The release Candidate will shut down every hour early next year and will stop working completely in June. You will be forced to buy Windows 7 or go back to XP or Vista.
1helpful
Top Samsung Computers & Internet Experts
Muzahura Frank
Marvin
Marvin
Fix It Fast...
Fix It Fast...
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
