Panasonic TH-42PV7HS 42 in. HDTV-Ready LCD TV Logo
fauzi ismail Posted on Sep 13, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My plasma TH-42PV7HS problem is after on first ok, a few second the picture over green. some people on tv hair is green colour. HELP ME!!
Henry Thomas
Level 3:
Genius:
  • Master 1,074 Answers
  • Posted on Sep 13, 2011
Henry  Thomas
Master
Level 3:
Genius:
Answers
1074
Questions
Helped
336493
Points
2402
This means your tv has a intermitent problem when the clour ic gets heated up it starts to give you green..so therefore you need to take your tv to a tech to have it repair by replacing the colour ic. good luck.
How to by panasonic panal th 42pv7hs
Yes it should still be covered find ur direction book and check out ur warranty and see if Panasonic will come out and cover it. Always beef up ur story you have been Panasonic owners for years when u call them. You have gotten all of ur friends and family to switch ect... Even if it's not covered sometimes loyalty goes a long way.
2answers
Panasonic TH-42PD50Uscreen colors all appear pink and green
the colour sensor on the picture display may have lost functioning....as in case of plasma tv`s the they use transistors for colour ......so better call a technician from the related company and do a check up.....no other solutions i hope.....
How to set up the colour on my Panasonic Viera TV
http://service.us.panasonic.com/OPERMANPDF/TH42PZ80U.PDF
Here is a copy of your users manual, it tells you how to adjust the color on the TV, Magnets do not affect Plasma TV's. If your picture looks bad you might have a defective or failing part if you just need to turn the red up or down or make the picture more blue or green the users manual tells you how to adjust it.
Panasonic plasma tv turns on but no picture or sound
Same issue with - Panasonic TH-50PX70A , power UP with red standby, then power ON by remote - only Gives GREEN led blinking 35-40 times, followed by solid green led with no no picture no sound.
>> Solution; unplug Plasma from AC 10-15min, then plug in & power on to Red standby led,, At this point - Power ON tv while holding down both -Volume Down and F (function Select) buttons (front panel door) at the same time turns picture ON,all ok.
1helpful
2answers
The pictures are mostly green - like instead of black it shows green
It's called Cyan and it's sound like you are having a problem on your D-board. Look for capacitors bulging out and replace first if not then order D-board
Th-50px70b
when doe s this happen on hd tv bad signal on antenna will cus ethat to happen heavey comprsed dvd bunred will also do it may need better antenna ok
2helpful
2answers
The green light on for 2 seconds and off again (Panasonic TH-42PWD5UY)!
PROFESSIONAL REPAIRER OF:
* cd-vcd-dvd-ld player.
* colour tv, Lcd/plasma tv.
* projection tv.
* prologic AMPS
* Grill/microwave oven's
* Digital proffesional camera.
* Digital camcorders.
* LCD/Digital projector.
* Hi-Fi music system.
* FAX machine.
* printer/scanner/copier.
* play station (PS1-PS2).
* X-BOX360.
DIAL..........: 9820380682
2helpful
2answers
Panasonic Viera Plasma TH-42PV7HS- Shutting down
CHANGE P.A BOARD. THIS BOARD IS FOR TUNNER VOLTAGE..IF THIS BOARD IS BAD, THE LED FLASH 10 TIMES IN RED AND THE TV NO TURN ON.
PANASONIC TV, TH-42PX60
If it's just one video plug, then perhaps you have to set av5 as being in colour somwhere in the menus.  If you require three wires for the pictures, as blue, green, and red, then make sure they aren't in the wrong ports.
Good luck.
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
