Question about Stanley 77 500 Intellilaser Pro Stud Sensor & Laser Level
I have a model no. 77-500 stud finder will this stud finder locate studs behind a fibro wall
Posted by denis6064 on
2 Related Answers
Mike258
Justin Case
  • 1498 Answers
SOURCE: How to operate the Stanley Stud Finder
Hi Gene,
  • Place the unit flat against the wall.
  • Press and hold the button.
  • The LED will come on for a second or two then go out.
  • Slowly move the unit laterally until the LEDs come on again.
  • When they top out, that is the beginning of the stud.
  • When they start to go back down, that is the end of the stud.
That's about it..
Best regards
Mike
Posted on Jun 05, 2010
Jack Spooner
  • 1015 Answers
SOURCE: my stanley stud sensor 200
Without knowing what room you are using it in it could be a underlayment of wire mesh that you are reading. If it is an older home this was used often as a backing for plaster instead of lath.Thank you.
Posted on Jun 06, 2011
How do internal capacitor stud finders work?
they detect changes in the dielectric constant of the wall. when a change in the dielectric constant is detected, it means that there is a dense object behind the wall- the stud
Jan 28, 2013 | Measuring Tools & Sensors
I need help finding a stub behind drywall
The stud finders are not expensive but you can sometimes use a magnet to find the nails. Also you might try shining a flashlight across the wall. The putty put over the nails will sometimes show up. Last resort is to tap on the wall and try and hear the areas that have support under them.
Jan 26, 2013 | Drywall
Do you know how to put this tv bracket on the wall?
Yes you will need a stud finder and a drill . Find you're studs in the wall. Mark them. Then you're gonna want to locate we're you're gonna want you're tv. The height. Put you're mount up to the wall making sure the whole that will holding the screws that go into the wall are over you're studs. Get a marker mark the wholes. Then get you're drill and drill in you're screws. If the screw are real thick then I would juggest drilling pre holes this way you're studs do not crack
Nov 01, 2012 | Televison & Video
How do i callibrate a draper 63401 detector.regard.
I have never met a stud finder that needed calibration. They should auto calibrate when you begin to search for a stud. Recalibrating is starting the search again. Start in a different location on the wall to get a different calibration. This particular stud finder has bad reports on amazon.
Jun 11, 2011 | Garden
I have plaster walls in an old house the stud finder just keeps beeping how does this thing work?
Your stud finder keeps beeping because old plaster walls have lath boards behind the plaster that are attached to the studs and running horizontally. Try adjusting the sensitivity of the stud finder by placing it on the wall and turning the sensitivity down until it just stops beeping. Then move it back and forth in a wide enough arc to be sure that you have crossed a stud, turning up the sensitivity ever so slightly until you get a tone when you cross a stud. Hope this works out for you.
May 08, 2011 | Stanley Garden
I have a 9-volt Strait-Line Stud Finder with 3 red LEDs and 1 green LED at the top end to mark the Stud Edge. I would appreciate it if I could receive step-by-step instructions on how to use the stud...
I suspect there are several models but I have one model. 1) Turn on the unit (if the green light is blinking replace the battery). 2) Calibrate the unit by holding it flat against the wall for 5 seconds until the red light goes off and the beep stops. Make sure you do not move the unit during the calibration or position the unit over a stud (try a spot 6-12" away from the corner of the wall - most studs are on 16" or 24" centers and the wood/metal stud is 1 1/2" thick). If the unit keeps beeping or the red light doesn't go off during the calibration, move the unit sideways 5-8" in case you are above a water pipe or other reason for "too deep a surface" for the unit.
3) Do not lift the unit off the wall or you will need to recalibrate it. Slide the unit across the wall. When the upper red light comes on and the beeping starts, that marks one edge of the object in the wall (stud). Continue until the red light goes off and the beeping stops. Mark the other edge of the stud by moving the stud finder in the opposite direction and marking when the red light comes on and the beeping starts. The center of the two marks is the center of the stud for securing anything to the wall.
If the beep persists over a 6" range, I'd check if you have any old cast-iron pipes or a door/window that was relocated in that wall. Repeating the test in a few places vertically along that spot of the wall will tell you there is a consistent large object in that location. Neither a filled in window or door will run the entire length of the wall but you could be finding the headers (the vertical framing of the opening would probably be ~4-6" wide (double or triple stud depening on the needs of the house design)).
I hope this helps.
(on another stud-finder that I borrow, you press the buttons on the right and left side to turn it on. Calibrate by holding it to the wall for a short while and then slide it across the wall. Note when the top red led lights and the beep starts. Repeat in reverse to find the other side of the stud.)
Sep 17, 2010 | Garden
How to use it
usually you put it up against the wall between studs. Then you press a button and gradually move it left or right to find the studs in the wall.
If you initially have it pressed against the wall at a stud, it won't work right.
Jul 10, 2010 | Ryobi WallTech Stud Finder Stud Finders
How do I know when i am on the stud
These usually need to be calibrated in a stud-less section of the wall so that the LED just goes out. Slide the finder over the wall slowly until the light turns on--that is the first edge. Continue moving and the LED should go out--that is the second edge. These two points should be marked lightly with a pencil and the midpoint between the marks locates the center of the stud. Note that these tools will respond to wiring in the wall the same way. Hope this helps!
May 07, 2010 | Strait-Line Strait Line 6041706 Stud...
Stanley 77 500 Intellilaser Pro Stud Sensor & Laser Level Logo
80 people viewed this question
Top Stanley Measuring Tools & Sensors Experts
Marvin
Marvin
Lawrence Oravetz
Frank Walton
Level 1 Expert
Are you a Stanley Measuring Tool and Sensor Expert? Answer questions, earn points and help others
