Question about Integra DTR-5.2 Receiver
My integra dtr-40.2 reciever will not turn off or change modes it is stuck on sat. volume works
Posted by brent_hurd61 on
Jdvillanueva
  • 2,098 Answers
Please unplug the unit from the outlet for 15 mins and then check if the symptoms still there.
Reset the unit to factory setting by following the steps below.
> Power on the unit.
> Press VCR/DVR button key + On/standby key at the same time to re-initialized the memory to factory settings.
Check also if the remote control is working fine. Aim the sensor of the remote control directly to your cellphone camera, while pressing any button key from the remote control (button key with an issue) you will be able to see the flash of an infrared emitted by the remote control indicating that it is working fine. Watch the video below for more info.
Jdvillanueva
Posted on Sep 13, 2011
How do I fix Cbt/sat no signal
The processor pcb board will need to be changed
Oct 09, 2014 | Integra Dtr-20.3 THX Select2 Plus AV...
"handshake" between DTR 5.9 and an LG Blu-ray player
You will have a defective processor pcb. You may want to see if you can get Integra to give you a one time repair on this.
Mar 26, 2014 | Integra Onkyo Rc-711m Dtr-4.9 / 5.9...
Integra DTR-5.6, no sound for am/fm tuner
reset receiver if that does not work You will have a defective processor pcb
Aug 24, 2013 | Integra DTR 5.6 Multi Media Amp
How do I set up an Integra DTR 7.8 for 3D display and audio
Your DTR-7.8 receiver is not 3D compatible. It does not support the new 1.4 HDMI. You have to have 1.4 HDMI and 1.4 cables for the 3D format.
You can bypass your receiver for the video though. Simply run your HDMI cord (1.4) from your Blue Ray to your Projector. Your audio can be ran from your Blue ray to your reciever.
May 17, 2012 | Integra Audio Players & Recorders
The reciver dosnt get a signal from the hdmi inputs both ps3 and blu ray have the same problem it is a dtr 5.9 integra
what you should do is make sure that your HDMI is cord is not in an awkard position, which like mine i have to unplug and plug back in to get a signal
Mar 01, 2010 | Integra DTR-5.1 Receiver
My left rear speaker has no sound. All others work. I have tested the speaker on a different reciever and it works fine. My reciever is a integra DTR 5.5
Swap your left and right rear speaker over. If you still get no sound from the right speaker connected to the left speaker connection on the receiver, then you have a fault on the receiver output. Check your manual first to see if any setting switch off the rear speaker before taking the unit for repair or replace
Nov 26, 2009 | Integra Audio Players & Recorders
No sound will come out the speakers until amp has sat on for half hour or so. After waiting, I have to flip through sound settings. Usually, the 'unplugged', or 'orchestra' setting will emit sound first....
check all speaker wires on the back and on the back of the speakers.if there is a short the amp will go in protect mode.
tap on it lightly and see if it comes on,there may be bad soldering on the pc board
Jul 18, 2009 | Integra DTR-7.1 Receiver
Low to no volume output from Integra DTR-5.2 receiver
most higher end integra's have a input level adjusment or input selection for each and every input. Perhaps you are not on the correct input, go to onscreen programming and check out the input level and input select - also try the tape in another input like tape 2 or cd. It will not hurt the receiver for a test. Also, if you are using the cheap cables from the manufacturer - try a pair of cables that you know work or go by some. BTW, you don't need to spend $40 for cables order them online through amazon or other store. Gold / sliver plated oxygen free are best.
Jun 30, 2009 | Integra DTR-5.2 Receiver
Volume control unstable
You may have an over heating problem as it the Integra has anautomatic cut out. The unit generates a huge amount of heat and needs to be positioned in a very well ventilated position.
Linian
Dec 11, 2007 | Integra DTR-5.1 Receiver
Integra DTR-5.2 Receiver Logo
967 people viewed this question
Top Integra Audio Players & Recorders Experts
Andrew Taylor
Andrew Taylor
Larry Stiles
Larry Stiles
Are you an Integra Audio Player and Recorder Expert? Answer questions, earn points and help others
