Hi
The issue is with the door switch or the thermostat located near the turntable motor is bad and should be replaced. If it was the fuse the unit will not even work, so I believe it is the door switch and I don't think that the control can go bad. Hope this helps...please post back for further assistance.
Daniel
The posted solution was accurate. I bought the door switch and just finished installing it on the microwave. The microwave works perfectly now. I'm very happy with this solution.
Thanks Daniel
Thanks Daniel
The previous solution seems to have worked temporarilly. Yesterday the same problem came back. This time I replaced the door switch again but the problem persisted. I noticed that there are 2 more identical switches clode the the one I replaced. I tried to replace those other switches but they seem to be so tight that I could not get them loose from the connectors. Should I keep on trying to disconnect these 2 switches to see if replacing one of them does the job?
Thanks
