Question about Necchi 6015 Mechanical Sewing Machine
Makes a whinning sound. Does it need oil & if so where to put it?
Posted by mdurbin333 on
ken dourof
  • 980 Answers
The whinning noise could be a slipping belt which you need to check, you should be able to take the side off to see
Posted on Sep 14, 2011
My sewing machine
The owner's manual is your best source for that information. If it's computerized, you need to follow the instructions exactly.
If it's a "mechanical" machine, you can use good quality oil (I use Tri-Flow Synthetic Lube) and put a drop every place where metal rubs against metal.
I can generally tell by the change of sound of the machine when it needs some TLC. I tend toclean & oil the shuttle every 8-10 hours of sewing and do a thorough oil every 40 hours.
Sep 14, 2018 | Brother Sewing Machines
My machine makes a terrible squeaking sound at the handwheel?when I wind the bobbin. What is squeaking and can I fix it myself?
Depends on the make & model...
Some older mechanical sewing machines need regular cleaning & oiling. Check your user manual.
Apr 20, 2015 | Sewing Machines
KENMORE 15612 MAKES SCREAMING SOUND WHEN RUN.
could possibly be that your wheel belt it to tight. Possibly you need to oil the stitching arm and other areas their should be small holes on sewing base and one on top beside the where the sewing arm is located
Jan 11, 2015 | Kenmore Sewing Machines
Elna Carina makes clicking noise each downstroke of the needle. Just cleaned and oiled the machine. Also put in a new needle. Help?
sounds like it's out of time just a little bit and the tip of the needle is just catching the shuttle.
Mar 14, 2013 | Sewing Machines
White quilters star 1780 is running slow, how do I fix it? Have already cleaned feed dog and shuttle, what else can I do?
You can send out to repair to have it lubricated & oiled, or you can do this yourself. Not recommended though if you have pets or kids where you are working on machine. Remove needle, thread, bobbin. There are screws underneath. Don't lose them! One drop good quality oil on moving parts so lay machine back on a towel, remove screws, keep foot pedal up on table so you don't accidentally hot it with your foot. All gears that are not greasy get a very small dollop of lubricant (Singer makes a good one comes in red &white tube). All parts moving get the oe drop oil. Put plate back on, firmly tighten screws. Never lube or oil plastic parts! A drop of oil any metal screw located on top of machine. Lift machine up and if tip can be removed, you can check moving parts needing oil there and replace lid. If front section opens--left of needle bar--open it up and oil moving parts..I usually just apply one drop oil to TOP of needle bar Close lid. Put one drop oil on shuttle hook bottom left. Never oil tension discs. Run machine with scrap of fabric to get her nice and smooth sailing. If motor sounds like it's running heavy after that, take in for service, but unless motor needs replacement, you should see noticeable improvement immediately. Good luck and hope this helps! Jimmy Remove screws on top
Apr 04, 2012 | Sewing Machines
I need a manual/where to place oil
go to the website of sewvacdoctor.com & email them about the machine to see if they know where you can get a manual & oiling
Mar 04, 2012 | Kenmore 15208 Mechanical Sewing Machine
Singer sewing michine model 3116, when sewing makes a
How long has it been since you oiled it? That may be all you need to do but be sure to use sewing machine oil
Dec 17, 2009 | Singer 3116 Simple
My old Kenmore sewing machine makes a loud squealing noise.
It sounds as if your machine needs a little oiling. If you have a clear machine oil (not 3 in 1). place a drop in the bobbin case area and if you will notice, you will see small holes on the bed and on the top of the machine. place a drop of oil into each of these holes. If you can take the top and bottom covers off, you can put a drop of oil every where you see a hole..some of the machines actually have the oil holes painted a red color. Also place a drop at the handwheel as well. Just remember when oiling, less is better. After oiling, run for a few minutes, if you feel it still needs a litte more, do the same, one drop at a time. After this, if you machine sets for a while, oil just before starting to sew, that way when you put the machine away the oil has been worked through and it should help prevent the squeaking when starting up again.
Mar 01, 2009 | Kenmore 15208 Mechanical Sewing Machine
Necchi 6015 Mechanical Sewing Machine Logo
88 people viewed this question
Top Necchi Sewing Machines Experts
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
