A
quick fix for most communication errors can be achieved by resetting the
printer and/or rebooting the PC. Simply disconnect the printer from your
computer. Reboot your pc. Unplug and re-plug the printer into the power source
to reset it. When the printer turns on, reconnect it to your computer. Then try
to print again once the computer fully recognizes the USB connection. If
that doesn't help, try the steps below: 1.
Disconnect the printer from your computer. 2.
Rebrick (pull out power supply, black box where the
power cord is plugged in at the back of the printer, and put it back after 30
seconds). 2.
On your computer, go to Control Panel > Printers and Faxes. 3.
Delete the Lexmark print object. 4.
Reboot your pc. 5.
When your pc turns on, reconnect the printer. 6.
Wait until your pc fully recognizes the USB connection. To check, go to Control
Panel > Printers and Faxes. If you see a new Lexmark print object in the
list, then try to print a document again to verify that the problem is fixed.
For Windows OS:
1. Go to Control Panel.
2. Open Printers and
Faxes.
3. Right-click on Lexmark
3600-4600 Series print object and click on Properties.
4. In the Lexmark 3600-4600 Series Properties window, go to Advanced tab. Click on Printing Defaults.
5. In the Lexmark 3600-4600 Series Printing Preferences window, under Ink Use, select Print
using black ink only. Click OK.
6. Click OK button in the
Lexmark 3600-4600 Series Properties window to save the changes.
Your printer will print in
black and white draft mode the next time you send a print job to the printer.
For Mac OS:
1. With the file (you wish
to print) open, go to Print. A window will pop up.
2. Select the Lexmark
printer.
3. Expand the arrow
pointing down beside printer name if you're not able to see other options for
printing. Look for Quality and Media.
4. Under Paper tab, select Print in Black
and White.
5. Save this as your
default print setting. Click Presets option and choose Save as. You can
personalize the name for this default print setting (e.g. Black and White Draft
or My Setting).
Select this Preset name
every time you print your files/documents.
