Question about 2wire Wireless-G 802.11g ADSL Gateway
I recently purchased a Trendnet wireless ethernet gaming module that is connected to my SONY PS2. I entered the user id and pswd that AT&T set up for me and loaded that info. into my game setting. The WPS light on my 2Wire router provided by AT&T will not light up. Can you help provide a solution?
Posted by mwood108 on
RudeRude
    Master:
  • 2wire Master
  • 526 Answers
Yeah what batman says and git yer self a hair cut and a job ya lay about.
Posted on Jan 06, 2018
batMichael
    Problem Solver:
  • 20 Answers
Stop wasting time with video games. there are more important things to do with your time. When the gaming thing stops being fun, it time to stop and do something else.
5 Related Answers
Anonymous
  • 205 Answers
SOURCE: Lost Ethernet and Wireless Connections in Modem
I've not used one of these 2wire boxes before, but I believe the default router's address is 192.168.0.1. Try this instead of gateway.2wire.net to see if you can gain access to the router. This is just the starting point, but see if it works.
Here's a link to, what I believe is, the router's manual.
Before you rate this please let me try to help some more. This could be a multi step process...
Posted on Dec 29, 2007
Anonymous
  • 19 Answers
SOURCE: 2WIRE 2701 router
You must log on to the browser interface of the router (usually for 2wire they use 192.168.1.254) run the set up wizard it will come to a screen which asks for a key code, this key code is provided by your ISP, you can try one of these and see if it works
if you have a PPPOE connection (you have a user name and password to log on to the internet with use this one.
5225-26Q4-2262-22AS-B28F
if it is not PPPOE use this
5225-26P4-6262-22AS-B2E7
to manually configure the router use this
5225-2374-WG62-22AS-BJ7P
If these do not work call your internet provider and ask them for the key code.
after that you should be all set.
Posted on Aug 06, 2008
Anonymous
  • 366 Answers
SOURCE: Set up wireless internet access using HG1701 2wire router
Check with this tip
Detail on this Wlan Router
"Connect power cord to router.
Wall Plate -> Router (using phone cord).
Router -> PC (using network cable).
  1. Power on router, when the lights settle, start the PC.
  2. Start IE in PC, type 192.168.1.254 in the address bar and press enter.
  3. Start configuring using the Telco's suplied info, namely PPPoE username and password. All other function works by default.
  4. The WEP key is the 10 digit number underneath the router (not the 12 digits S/N number).
Posted on Jan 20, 2009
Anonymous
  • 611 Answers
SOURCE: Ethernet cable problem
not
Posted on Mar 06, 2009
Anonymous
SOURCE: online gaming drop outs with wifi 2wire modem connection
i got the same problem, quick solution for now is to set the wireless to 802.11b <----, slower local network but shouldnt notice to much on ur internet
still not sure why 54Mbits drops the internet on that modem might need a firm ware upgrade
good luck with that
Posted on May 02, 2009
How do I set up a secure password?
For trendnet
Your Trendnet wireless router lets you broadcast your home network across your entire house, so you can access the Internet in any room. This signal may be powerful enough to extend into neighbors' houses, where they could easily jump on the network if it is unsecured. To protect your network, set up Wireless Encryption Protocol, or WEP, to encrypt data and prevent access unless the user enters the correct password.
Type "http://192.168.0.1" in your Internet browser's address bar and press "Enter." Enter "admin" for the username and leave the password field blank. Click "Log In" to log into your Trendnet wireless router's administrative program. Click "Wireless" from the left pane of the "Basic" tab. Click "WEP" under the "Wireless Security Mode" section at the bottom of the screen. Enter your preferred password for the network. A strong password is made up of a random selection of numbers and letters. Click "Save Settings" at the top of the screen to save your WEP settings.
trendnet wireless router users guide
http://downloads.trendnet.com/tew-611brp/manual/ug_tew-611brp.pdf
I HAVE TRENDNET ROUTER. HOW DO I SET IT UP FOR WIRELESS. I SEE NO WHERE TO LOGIN AND IT KEEPS ASKING ME FOR IT
Turn your computer off.
Turn the router off.
Use an Ethernet cable to connect from one of the 'LAN' ports on the router to the network-port on your computer.
Turn the router on.
Turn your computer on, and let Windows start.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
Look for output similar to: Default gateway ... 192.168.123.456
Start Internet Explorer
Type http://192.168.123.456
Press Enter
You will see the router's "login" screen.
Try several combinations of ID/password:
'admin'/(leave the password blank)
(leave the ID blank)/'admin' password
'admin'/'admin'
One of them should be correct.
Then, click to run the Wireless Network Setup Wizard to define your wireless network.
How do you connect the PS3 to internet (wireless)????
First power on your PS3 , TV , & Router ( if you own the internet connection your going to connect to ) . Then select your User ID upon login . Scroll Left till you hit the Settings Menu , scroll all the way to the bottom & select Network Settings . Now select Internet Connection Settings , select Easy , Wireless , Scan . Now select your Wireless Network from the list that appears , confirm the SSID ( network name ) , & the type of Security Setting ( if you don't know connect a PC to the Wireless Connection & you can see the proper settings there ) , Enter a WPA Key or other type of Encryption if neccesarry , now confirm & test your Connection . It should run through a series of tests from connecting to the network , to a speed test . If all went right you should now be online & ready to game .
1helpful
How to reset the security key of my trendnet tew-430apb 54mbps wireless access point?
To change your router wireless security
  • Support site here http://www.trendnet.com/products/proddetail.asp?prod=150_TEW-430APB&cat=83
  • User guide here http://www.trendnet.com/asp/download_manager/inc_downloading.asp?iFile=10853
  • Quick setup here http://www.trendnet.com/asp/download_manager/inc_downloading.asp?iFile=10856
Connect your PC to the router with a cable to one of the LAN connections - Now you need to Log into the setup of the router - to do that open a web browser, use Internet explorer (some routers setup pages do not work correctly with other browsers) In the browser address bar - Enter IP address http://192.168.1.100 to the address location. When there is a screen needs to enter the User name and Password, both of the default Username and Password is “admin”
Now you can goto the wireless section or secruity section and set the type of encyption to WEP, WPA, WPA-PSK etc and then make up your own password. See Page 12 of the User Manual
On the PC Double click on the wireless connection in the system tray (bottom right hand side of screen) and then connect manually to your wireless signal - you will be asked for the password you set in the router.
Now you are connected.
You may need to remove any old wireless profiles you have on the PC/Laptops
Wireless Profiles - Vista/Windows 7: http://mgmcc.forumotion.net/networking-tutorials-f17/removing-an-existing-wireless-profile-t109.htm http://www.tp-link.com/support/showfaq.asp?id=214 - delete the wireless profiles Start> control Panel> classic view> network and sharing center> manage wireless networks Delete the profiles you will then have to enter the wireless security key for any networks you connect to --
Wireless Profiles - XP http://mgmcc.forumotion.net/networking-tutorials-f17/removing-an-existing-wireless-profile-t109.htm http://www.tp-link.com/support/showfaq.asp?id=186 - delete the preferred networks start> control panel> network connections> right click on the wireless connection listed wireless networks tab in the preferred network list click on each one and - remove button
4helpful
2answers
How to set up WEP password for my Motorola WR850G wireless router?
I got this info from the online User Manual:
  1. go to web address http://192.168.10.1/
  2. Enter the User ID. The default factory setting is "admin"
  3. Enter the Password. The default factory setting is "motorola"
  4. Click Control Panel > Device Security
  5. In the Login User ID field, enter your User ID. Create an ID that contains multiple casesensitive characters as well as numbers. It cannot be longer than 64 bytes.
  6. In the Login Password field, enter your Login Password. Create a password that contains multiple case-sensitive characters as well as numbers and symbols like “_ + )”.
  7. Re-enter your Password.
  8. Click Apply.
  9. Once the settings have been accepted, click Restart and log back into the Configuration Utility using your new User ID and Password.
  10. Select Wireless > Basic.
  11. Change the SSID to a user-friendly name and click Apply.
  12. Navigate to Wireless > Security.
  13. Select WPA-PSK from the ESS Authentication options.
  14. Select TKIP from Encryption Status options.
  15. Click Apply and then click Restart. Your wireless security configuration is now complete.
WEP is easily hacked by hackers. WPA-PSK with TKIP encryption is the newest, most secure wireless security measures and you can follow these directions to set it up this way.
Hope this helps you out! If so please give me positive rating (4 thumbs up)
2answers
Im from manila..can't play a game online...
most games require you have a certain amount of mbps (speed of connection) to prevent lagging. a slow connection may be your problem. if you are using a wireless adapter try actually plugging the ethernet cable into the console. also, have you set up your network options and saved them to a memory card?
Can't connect my gaming adapter to my wireless network
If the ethernet light -( )- is off, flip the X - II switch to its other setting.
If the wireless light is off, click on the channel button, it should me IN. If still cannot connect, then you will need to setup the wireless settings of the gaming adapter.
First, you need to know the wireless settings on your wireless router or access point. Take note of the wireless network name (SSID) and wireless security settings.
Connect the gaming adapter to the router using an ethernet cable. Flip the switch on the adapter to straight through (II).
Then insert the Setup CD of the WGA11B to your computer. Click on the Setup button once the wizard is up. It will then show you the current settings, so just click next.
It will ask you for the password of the adapter, just type admin.
Make sure that Obtain IP address automatically is selected, then click next.
On the Profile configuration, select Internet for the mode.
Then enter the SSID and select WEP if wireless security is enabled on the wireless router. Type the passphrase of the WEP key. Then click No to complete the configuration.
Connect the gaming adapter back to the PS2.
Problems with PS2 Network Adapter and FIOS
a number of things
1. that the ps2 is just too old to recognize the router.
2. that the router is not set up for DHCP (automatically assign an IP address)
3. your ps2 is configured for a static ip address
check those things... also, do you have other things connected by ethernet? if those work, the problem is on the ps2.
3helpful
2answers
Manual Setup of Trendnet Router
1. Open Internet Explorer 5.0 or above Internet browser.
2. Enter IP address http://192.168.10.1 (the factory-default IP address setting) to
the URL web address location.
3. When the following dialog box appears, enter the user name and password to
login to the main configuration window, the default username and password is “admin”.
New Vista laptop and problems setting up wireless
Chances are the wireless portion of the trendnet software is not compatible with vista. I would uninstall the trendnet software or let windows control the wireless portion of it.
Check to see if you are using any encryption ie. wep or wpa or wpa-tsk. If you are then you will need to enter the network key in windows.
good luck
smeags.
Open Questions:
See all 2wire Wireless-G 802.11g ADSL Gateway Questions
2wire Wireless-G 802.11g ADSL Gateway Logo
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
