SOURCE: JVC TH-S3 System
try to check the av output wire if its properly connected according to its color.
SOURCE: i hv a JVC th-s3 dvd player who's dvd tray is
You have to remove the changer assy. See why it's jammed and retime it. I have seen a lot of these with jammed changers. If you remove the dvd assy from the bottom there are 2 gear sets to the side. 1 moves trays up and down and the other draws tray in and loads the disc. All I can say is if you are mechanically inclined you can figure it out. If not have it serviced.
SOURCE: Hi - I purchased a JVC TH-S3 Home Theatre System
Check the unit for a sticker stating it's electrical approval numbers. There should be the voltage and cycles required. There could well be a switch of some description near this sticker Saying 120-240 with an arrow showing which way to put the switch to change the voltage. This usually involves removing a plate of some description to stop someone changing it by mistake. Don't forget the cycles as well. The UK uses 50hz or 50 cycles whilst the USA uses 60 cycles. Using the wrong one could burn the power supply out and even cause a fire. Many smaller electrical items are self seeking when it comes to power supplies but large components such as TVs and HiFi units are usually set.
If the sticker says 240 volts 50 hz then thats for the UK
If it has 120 volts 60 hz as well then it's possible to use in the US. Luckily it has a dual power supply built in. The chances of this is rather rare so you could have a boat anchor instead of a HiFi
Whatever you do DON'T just chabge the plug and try it out. There'll be smoke for sure.
If you are unsure get it checked by an electrician.
One way out would be to buy a transformer which changes the 120 volts to 240 volts but you will still have the cycles to worry about. So unless the cycles are changeable you can't use the hifi in the US.
Sorry for the bad news If it's not too large it's possible to recover some money by selling in on Ebay in The UK or Australia or any other country using 240/50hz
SOURCE: jvc th-s3 won't turn on...blue light flashes
from my experience, I think your player is having a power problem. It must have received excess voltage/irregular power supply which has damaged an IC or capacitor on the power board of the player.
Sometimes this excess power supply might damage the player's main board. This is why it is advice able that you use step down for your player, because DVD player don't need excess power as something might be damaged.
To solve this problem, you will be needing a meter. Open the player, use the meter to read the components on the power board as it will help you discover the component that got damaged and you can then replace the bad component.
But if you do not have the knowledge of fixing this problem, you might be needing the help of a service technician.
Take care.
