Question about Dane-Elec DaneElec 4GB USB Drive Copper Hard Drive
My dane elec 4gb flash drive does not work in my computer dell inspiron xp?
Posted by rubyallen on
Brian Sullivan
  • Dane-Elec Master
  • 27,725 Answers
If your computer came with a motherboard disk the drivers could be on it.
Click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
Click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
Click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
then you restore it to its default status
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
Rather doing a driver hunt which can take hours
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
Windows XP/Vista/7/8
it might take some time being a freeware driver solution
note: it will find all of your outdated drivers
This is a free driver solutions.
This will automatically search for and find the correct driver
you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
Hope this helps.
Posted on Dec 07, 2012
3 Related Answers
Colin
  • 1584 Answers
SOURCE: My Dane-elec 4GB usb flash drive , no drivers?
Try it in another PC, if the same its a writeoff.
Posted on Mar 09, 2010
rommelalilin
Rommel Alilin
  • 2178 Answers
SOURCE: I can't open the red cover on a dane-elec 4gb
Pull it in half.
Posted on Nov 10, 2010
samwise342
  • 51 Answers
SOURCE: Dane Elec 4gb USB Not Readable
Try it in a different computer or even a different usb port on the computer that you are using. If a second computer gives you the same error, then the drive is either damaged or its filesystem is corrupted. In the first case there is not much you can do. In the second case you may be able to reformat it to make it work, but you would lose any data that was on it.
Posted on Mar 25, 2010
My computer doesn't recognize my dane-elec 8gb usb stick , although other usb devices do work.
1. Try a different USB port. If other ports recognize it, then the original port is fried. 2. Try a different computer. If the other computer does not recognize it, then your flash drive is damaged.
Good Luck!
Aug 19, 2011 | Dane-Elec DaneElec 4GB USB Drive Copper...
I am not able to use my dane elec 4gb Flash Drive. I used it the night before but now the computer/system does not recognize it.
control panel admistrive tools,computer management,device manager scroll down universal serial bus controllers you could see a yellow question mark? right click to reinstall drivers or right click select properties general troubleshoot or driver to uninstall,disable,roll back driver
hope this helps
Oct 26, 2010 | Dane-Elec DaneElec 4GB USB Drive Copper...
Mar 25, 2010 | Dane-Elec DaneElec 4GB USB Drive Copper...
Missing driver for dane elec 4gb usb flash pen (Operating system XP)
No zMate Pen driver is necessary to work out with Windows Millenium, Windows 2000, Windows XP and MAC OS 9.1 and more: they are plug and play.
but try this site:
http://www.dane-elec.fr/scripts/home/publigen/content/templates/TPL_ADV_INFO_C2_S4.asp?P=352&L=EN
Jan 11, 2010 | Dane-Elec DaneElec 4GB USB Drive Copper...
Dane-Elec DaneElec 4GB USB Drive Copper Hard Drive Logo
152 people viewed this question
Top Dane-Elec Computers & Internet Experts
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
Hetman Software
Hetman Software
Are you a Dane-Elec Computer and Internet Expert? Answer questions, earn points and help others
