Recently my friend divert the call but now I could not deactivate. Because there is no option 'call settings' in 'settings' menu of S5233S. Please tell
You can now divert important calls to another mobile phone or
landline if you are unable to take a call in case: you miss a call, are
busy, are out of reach or phone switched of.
Activate
Go to the 'Call Divert' menu on your mobile phone
Select 'Divert if out of reach' option
Select 'Activate', followed by to other number option
Enter the number in the to other number section
Your Call Divert service will now be selected
Deactivate
To deactivate go to 'Call Divert' menu and select deactivate / cancel option.
Also:
To forward all calls:
to start, enter **21*number #
to stop, enter ##21#
To forward calls while you´re speaking to someone else:
to start, enter **67*number #
to stop, enter ##67#
To forward calls if you don´t answer the incoming caller within 30 seconds:
to start, enter **61*number #
to stop, enter ##61#
To forward calls if your cell phone is switched off or is out of reach
to start, enter **62*number #
to stop, enter ##62#
To cancel all preset conditions:
enter ##002#
You will not be charged for activation or deactivation of this service. Only the call divert will be charged as a separate call.
Activate
Deactivate
Also:
To deactivate your call diverts, go to 'settings' on your phone, 'call settings' and then 'call divert'. When you select it, choose the option to 'canel all diverts'. If you have done this, and the call divert is still active, then contact your mobile service providers, they would help you fix the problem on the network. Hope that helps? Success.
Sir, as you told us about your problem the only solution of this problem is to deactivate the diverter. Maybe some friend of your incidentally put on the diverter.But you don't have to worry I will completely satisfy you and solve your problem. :)
Please follow the steps given as below.
> Go on settings. > Then on call settings. > Then on divertor settings sir and by clicking on divertor it gets deactivate. :)
Call forward or call divert,
the
same features just different names in some models of phones. Only the
name of the service says that it is diverting calls. There is 4
situations for activation and can be activated via the mobile device or
directly by entering codes on the display phone. The function codes and
their ability to use depends on the network operator. Codes: ** 21 * number that diverts calls with code of network operator # OK, yes or call it will divert all incoming calls unconditionally ##21# ok, yes or call it will deactivate this divert. *#21# ok, yes or call it will check status. ** 61 * number that diverts calls with code of network operator # OK, yes or call it will divert incoming calls when you do not want or can not answer the call ##61# ok, yes or call it will deactivate this divert. *#61# ok, yes or call it will check status. ** 67 * number that diverts calls with code of network operator # OK, yes or call it will divert incoming calls when your line is busy
##67# ok, yes or call it will deactivate this divert. *#67# ok, yes or call it will check status. ** 62 * number that diverts calls with code of network operator # OK, yes or call it will divert incoming calls when you are unavailable ##62# ok, yes or call it will deactivate this divert. *#62# ok, yes or call it will check status. ##002# ok, yes or call it will deactivate all divert. If the codes not working you have that option in your phone, it is in call settings. You choose option and then insert a number for diverting calls. This service is not free, and you must contact your network operator for prices. By!!!
Its showing Active diverts because your call diverts is active. May be you have set a call diverts where if you are unreachable your calls gets transfered to voice mail. To deactivate Active diverts. Go to Tools -> Settings -> Call Diverts -> Options -> Cancel all diverts Hope this helps.
try to check the settings of the phone. see if you have call barring for incoming activated
~ menu
~ setting
~ call settings
~ voice call
~ call barring
~ make sure all incoming calls is set to DEACTIVATED
you can also try to check if call divert is also set
~ menu
~ setting
~ call settings
~ voice call
~ call diverting
~ make sure always is set to DEACTIVATED
hope that helps.. :)
