Question about iLO 3200 32 in. LCD Television
My ilo smell like it is burning when i plug it in and now it shuts itself off when i turn it on. do i need to fix it or throw it away?
Posted by tcox008 on
Abctay.com
    Master:
  • iLO Master
  • 372 Answers
Abctay is a tv parts online shop,you can search the TV Parts models in abctay.com,I think you can find what you need ,but you should know which parts is broken,or u can'nt fix it.
Posted on Dec 06, 2018
Tek 12-3
    New Friend:
  • 59 Answers
The sense of smell is a wonderful thing. Usually when you smell something burning and you shut it off quick enough it can be repaired. When you see plumes of smoke it's usually too late. If you have a reputable repairman he will be able to tell you if it's repairable or not. My gut feeling is, you should bury it in a quiet spot in the back yard. Sorry :(
Posted on Sep 12, 2011
Refrigerator control panel failure, causing dispenser to run for hours, filling refrigerator with burned plastic smell
I have a artic and it has a motherboard in it. This is the most common problem.They are easy to replace and you can get one on the internet pretty cheap.First look at the mobo for any burnt spots on it. If so then get the # off the board and search for it.
Mar 16, 2014 | GE Refrigerators
How do i fix my home stereo amp
sounds like an easy repair. My advice : bad capacitor
good luck!
Nov 28, 2013 | Audio Players & Recorders
Burning smell from oil heater
Pull the controls off the front,and inspect the thermostat connections to see if they are burned up,also the other switches will do the same thing.If you can`t see a problem,then the element is burned out,throw it away and buy a new one.
Sep 24, 2009 | DeLonghi 9707 Oil Filled Radiator Heater
Ilo mp3 player shut off after a few minutes
Did not get a solution. My solution is to throw it away!!!!!!
Aug 23, 2008 | iLO (2 GB) MP3 Player
TV shuts off by itself and has a burning smell
mine is doing the same thing but i was able to pinpoint it to a capacitor arching and smoking. haven't replaced it yet so i'm not sure if it's just a bad capacitor or a more involved issue.
Jul 29, 2008 | RCA D52W19 52" Rear Projection Television
Motor problem
I had to throw the machine away before it burned my house down. There is no way to fix it; had to replace it.
May 22, 2008 | Bissell 1770 Quicksteamer II Upright...
Burning smell from Microwave
If you clean any appliances always plug out the unit power supply do spray any liquid in the unit that can enter inside the control, instead just wipe it with rug not spray. In this situation you have to call for a qualified technician. Maybe there are some wires that burned or rust in the control that cause the short circuit inside the unit..
Dec 27, 2007 | Whirlpool MH7135XE Microwave Oven
Burned images
when images are burned in the lcd panel they are just burned in
he lcd panel will need replacement.
Oct 22, 2007 | iLO 3200 32 in. LCD Television
Stuck on "Hello"
This product is known for freezing up. You can get it fixed but it will cost more than you paid for the machine. Best advice, throw it away and buy a name brand recorder. The company will stand behind their products instead of dodging their responsibility of making a decent machine and ripping everyone off. I learned the hard way too, and yes, it hurts the pride.
Sep 11, 2006 | iLO DVDR05 DVD Recorder
iLO 3200 32 in. LCD Television Logo
70 people viewed this question
Top iLO Televison & Video Experts
Lee Hodgson
Lee Hodgson
CoppellTVRepair.com
matt martin
matt martin
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
