Basically you have to find the nearest dealer to you and they should be able to tell you where the repair depot is and how much it will cost. If you go to
http://www.fujifilm.com/worldwide/
And locate the nearest place to you or contact Fuji using one of the contact email or phone numbers.
Having said all that I would caution you that the repair will not be cheap if they will do it. If the lens is broken due to a accidental drop etc then they classify it as user abuse and will not touch it. If the lens has mechanically failed ie the little motor went out then they will repair it. The problem is the repair may cost more than just buying a new camera. If you have any warranty and the problem was not your doing then you should be able to get it fixed with no problem. If you don't have warranty just look for a new camera price and then get Fuji to estimate the repair cost for you.
The non functioning of the camerazoom can be a fault in the failure of the Main control system or the drive. A simple was is to reset and we can try by removing the battery and card for some time. Now replace only the battery and while switching power ON, tap the lens hood on the palm of your hands so as to disengage any dirt or mechanism being struck.
Use some air to blow between the lens to dislodge any sand particles struck inside. Unless you are familiar with handling of small devices must the camera be opened. If so check the voltage on the motor drive, check the auto focus and Zoom drives, it must be free with manual movement. If jammed the motor can be removed and released. If none of these works then you can think of taking consensus with the service centre.
Get estimate before you decide. It will be good to have it checked at the authorised service as you do not have to run around for spares.
Thank You for using Fixya
