Just double click the clock on the lower right corner of your screen. It will give you the option to edit the date and time of your machine. If it prevents you from changing the date, that means you need an administrator account to edit the date.
Regards
Double click the time display on
the bottom right of the computer screen to open the date and time
properties box. Use the tabs to access settings for time, date, time
zone and Web-based time updates.
Set the clock for the correct
time zone. Click the "Time zone" tab. Click the drop-down menu for time
zone choices. Click the time zone choice for your area. Click a check in
the box for automatic updates on daylight saving time changes. Click
the "Apply" button, then the "OK" button.
Set the correct date. Click the
"Date and time" tab to show clock and calendar settings. Click the
drop-down menu displaying the name of a month to change the month. Use
the up-and-down arrow keys to change the year being displayed. Click on a
date on the calendar image to set the date. The time can be manually
set on this page also.
Set the current time. Use the
up-and-down arrow keys next to the numeric time display on the date and
time page to manually set the clock. Click "Apply," then click "OK" to
confirm date and time settings.
5
Click the "Internet time" tab to
use a Web-based clock for updates to automatically correct the time.
Click the "Server" drop-down menu for listed Internet time sources.
Click a check mark into the check box for automatic synchronizing. Click
the "Update now" button, then click the "OK" button.
Setting the date and time in Windows 10 Note: Windows 10 automatically adjusts your date and time for you and only allows you to adjust the time if you disable this feature. If the wrong date and time is being set, you may need to change your time zone, or if you want to increase or decrease the time for other reasons, follow the steps below.
Right-click or tap on the date and time in the Windows Notification Area in the bottom right corner of the screen. Click Adjust date/time. Make sure your Time zone is set properly if your computer is displaying the wrong time. To manually adjust the time, turn off the Set time automatically option and then click the Change button.
Setting the date and time in Windows 8 In the lower right-hand corner of the screen, click or tap the Windows Notification Area where you see the date and time. Select Change date and time settings... in the bottom of the window that appears (shown below). Time and Date in Windows 8
In the Date and Time window, under the Date and Time tab, click the Change date and time... button. Make your adjustments and click OK. Click OK on the main Date and Time window to save the changes.
MacOS
Choose Apple menu > System Preferences, then click Date & Time.
Click Date & Time, then set the date and time automatically or manually.
Automatically: Select “Set date and time automatically,” then choose the network time server for your region.
Manually: Deselect “Set date and time automatically,” click today’s date on the calendar, drag the clock’s hands to show the correct time (or enter the time), then click Save.
Click Time Zone, then set the time zone automatically or manually.
Automatically: Select “Set time zone automatically using current location.”
Manually: Deselect “Set time zone automatically using current location,” click a location on the map, click the Closest City pop-up menu, then choose the city closest to your location.
Click Clock.
Show date and time in menu bar: Select the checkbox to see the date and time in the top-left corner of the menu bar. In “Time options” and “Date options,” set how you want the date and time to appear.
Announce the time: Select the checkbox to hear the time announced, then choose when you want it announced. If you want, you can customize the voice.
What seems to be the problem with the date and time?
If you want to change the date and time settings, then you can click on the time on the bottom right corner of your screen. There you can change the time and date settings. Or if date and time are always changing whatever you do then you would need to change the CMOS battery of your computer.
Get into the Bios or System Setup. When you power on the computer watch the screen and it will tell you which key to press to get into the Bios or System Setup.
You can also adjust the date and time by Right Clicking on the time at the bottom right corner of the screen and select Adjust Date/Time.
Regards
In all Canon PowerShot and IXUS series cameras date and time can be stamped on the photos shot in Post Card Size, to set the Camera into this mode do the following:
On Camera in Shooting mode (Live view is visible on LCD)
Press Function/Set button once
From right-left move to the Post Card Size
Press Function/Set again.
Now, Press Menu Button
From up-down move down
On Stamp Date (Option Name written, Visible on the Right top Corner of Screen)
From right-left move and select you want only Date or Date and Time both.
Press Menu again
Now, you are ready.
use your mouse curser; place over "time" in lower right corner of screen in bottom taskbar; right click;should have adjust date/time; left click;adjust date/time
I assume you mean date/time right click with the mouse on the time at bottom right hand corner a list will appear left click with mouse on adjust date\time a screen will appear and you can adjust time and date on that screen.
Another way to access this control is left click start button highlight control panel double left click with mouse and double left click on date/time option
I dont know where to find an instructions booklet but I can help with setting the time/date:
To set the time and date (you have to do them both together):
First press and hold the 'CLOCK' button until it beeps then let go.
You will then be required to select the year by scrolling up or down with the 'TIME SET' rocker switch on the right hand side.
Once you have the right time, press the 'ENTER' button, to the right of the rocker switch once.
You will then be required to select the the month. Do this by once again using the 'TIME SET' rocker switch and then pressing 'ENTER'.
You will need to repeat this to select the date (day).
You then use this same process to select the time, starting with the hour and then the minute.
After you have finnished selecting the minute, press the 'ENTER' button once and then the set time, with the day in the top left corner will be shown. You do not need to press anything else. Your clock is now set.
REMEMBER to press the 'ENTER' button after selecting each thing to move you on to the next thing to set.
TIP; Beside the 'CLOCK' button there is a button which says 'D.S.T SUMMER T'. This is the button which automatically switches your clock from british summer time to winter time and back again. It means that you do not need to reset your clock every time. Make sure that it is in the right setting when you set the clock otherwise it could get confusing. You will know if it is on british summer time because a small sun with a clock face appears in the top right corner of the screen.
