Visonik VX3 3-Way Electronic Crossover Network Car Audio Amplifier Logo
James Benish Posted on Sep 12, 2011
Cant find owners manual for visonik vx3 electronic crossover
I have a visonik V8EQ, that i just bought last weekend, & it didn't with a manual or install instructions, i tried going to web site i found on warranty card, but i get an error message. i searched the...
I tried my best but was not able to find one also. I was able to browse their website and its not there on the downloads page.
Your best bet would be to contact them at [email protected]. The shop where you bought the device should give you the manual. How will you install it if you don't have a guide.
Best of luck!
How do I install a Visonik Subwoofer Box to a Jeep Cherokee 99'? I am going to keep my factory radio and amplifier.
no you cant just use any subwoofer box you have to buy the box made for jeeps or you will lose all you bass
Motorla vx3 will not read memory card
try another memory card if that does not work then take the phone to a mobile center to have them fix the problem for you.
Intallation of amp
Don't! The amp will draw many more amps than what the 12V outlet (like a cigarette lighter) can handle. Most amps are wired directly to the battery (for the +12V) with a 30A or higher fuse (reference the owner's manual)
Bi-amp
After examining a picture of a 5802 ( I have been servicing adcom for over 20 years ), these are not bi amp posts, but bi wire posts.
Bi-amp means that 2 amps are being used, one for highs, one for lows. This means that you have no crossovers in the speakers, instead, you have an electronic crossover between the amps and the pre-amp. The highs and lows are separated in the electronic crossover. One amp handles the lows, one handles the highs.
Bi-wire means that you have the crossovers still inside the speakers. The amp handles the full range of music ( highs-mids-lows ). Different kinds of speaker wire produce different results. If you have bi-Wire terminals on your speaker, they come with shorting wires, that tie the tweeter + to the woofer + on the back of the speaker, and the tweeter - to the woofer - . When the shorting wires are removed completely, you have now electrically separated the tweeter and woofer from each other, while maintinaing the crossovers ( inside the speaker ) for each.When this is done, you can now bi-wire the speakers and amp, and use different kinds of wire for the lower frequencies and the upper frequencies, depending on your ears ( everyone hears a little differently, thats why there are so may makers of components, and wire ).
Why do we have crossovers?.....the tweeter voice coils ( the things that make the sound ) are made of hair thin wire. This wire cannot handle much power and if you were to put bass in to a tweeter, you would burn the tweeter out almost instantly. A tweeter is a very light, fast moving device which can react very quickly to high frequency sounds ( symbols, triangles, guitar strings....). Woofers are more rugged. They have voice coils made of heavier wire and are designed for larger movements that Bass demands. Subsequently, woofers aren't very good for high frequencies because they are slower devices.
So what do we do ?.....Keep the lows away from the tweter and the highs away from the woofer.....thats the job of the crossover.
In the event that your speaker has the crossover OUTSIDE the speaker box, you should check ( as always ) with the manufacturer of the speaker to see how it can be changed to suit your needs. Remember to always read and follow your owners manual. Good luck....Rob
Installing visonik bass system
Here is a link to visonik to download manuals.
http://old.visonik.de/en/downloads.php
If you let me know your model number of the sub, vehicle make and model, and brand and model of headunit or CD player you have then i can provide wiring color codes, recommended wire routing locations, etc...
Broken Potentiometer
Contact the manufacturer in the owners manual or from where you purchased the unit from, ask them where or who the manufacturer is. Good Luck
Top Visonik Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Visonik Car Audio and Video Expert? Answer questions, earn points and help others
