Question about Ultrex 2-in-1 (9qt) 8-Quart
The recalled 8 qt ultrex ll pressure cooker model # 11302c will the lid come off on its own or does it just not lock while under pressure?
Posted by rmilam on
Richard Morris
    Master:
  • 577 Answers
Halt, do not use this pressure cook. The lid is suspose to lock. This means the lid become a dangerous fly object if it came off under pressure, plus extremely hot boiling water and the contents of the pressure cooker. Beside possible dying from the lid, and if one survives the flying lid, one will be will scalded by the contents of the pressure cooker. Another pressure cooker manufactured in China. Sorry, GB...stewbison
Posted on Sep 12, 2011
Where can i find a manual for ultrex pressure cooker?
The company had a major recall and went out of business. No manuals appear to be available on the web.
Here are some general instructions you can use:
1 Set up your cooker. Place your Ultrex Pressure Cooker on the stove. Remove the lid and pour in no more than 2 inches of water. Depending on what you are cooking the amount of water will vary. More water will ultimately cook larger amounts of food, but you will need to refer to your specific model's instructions on this matter.
  • 2 Put in the food you wish to cook. Close and lock the lid firm to the pot. Make sure it is locked securely so none of contents boil out of the top.
  • 3 Turn on your burner to high heat for approximately ten minutes. Allow the water to boil.
  • 4 Turn the stove down to a low setting after the water is boiling in the cooker. Flip the pressure valve closed and allow your food to simmer.
  • Set the pressure valve to ten pounds. For vegetables, cook 30 to 45 minutes. For meats, cook 45 to 60 minutes.5
  • 6 Open the pressure valve and allow the pressure to discharge. Unlock and remove the lid to find your fully cooked meal.
  • Aug 25, 2014 | Ultrex Crock Pots & Slow Cookers
    Liner cracked. Can it be purchased from anywhere?
    Innova, Inc.
    P 800-767-5160
    F 913-541-8561
    [email protected]
    Ultrex Slowster 8 qt slow cooker 9 qt roaster Model 08393
    Sep 19, 2011 | Ultrex 2-in-1 (9qt) 8-Quart
    Bought a new Ultrex II 6-quart non-stick pressure cooker
    I found numerous recipes on 'About.com' Type in the receipe that you are wanting and add pressure cooker to the search. I have also found recipes on other search engines.
    Dec 19, 2008 | Ultrex 2-in-1 (9qt) 8-Quart
    Ultrex model 08393
    My inside crock also crackes. Where can I get another?
    thanks,
    May 20, 2008 | Ultrex 2-in-1 (9qt) 8-Quart
    Ultrex pressure cooker manual
    where do i get a tower pressure cooker manual from?
    Apr 21, 2008 | Crock Pots & Slow Cookers
    I can't open my new Ultrex 2 Pressure cooker model 11302
    It's almost certainly due to atmospheric pressure. Warm it slightly and it will open.
    I had the same problem with an underwater dive torch. Left Johannesburg (1000 metres above sea level) and went to Mauritius (10 metres above sea level) and I couldn't open torch!
    Apr 19, 2008 | Ultrex 2-in-1 (9qt) 8-Quart
    Lid to Ultrex slow cooker suddenly exploded in the sink
    I don't have a problem with the lid but,
    I was starting my meal on top of the stove in the crock pot and the crock pot broke and spilled everything. Can I get a new replacement pot?
    Dec 03, 2007 | Crock Pots & Slow Cookers
    Ultrex 2-in-1 (9qt) 8-Quart Logo
    1,077 people viewed this question
    Top Ultrex Crock Pots & Slow Cookers Experts
    Marvin
    Marvin
    Andrew Taylor
    Andrew Taylor
    ray gallant
    Are you an Ultrex Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
