Question about Sony DAV-FR10W System
I'm using the sony dream system (dav-fr10w). I just want to use it to watch cable tv, but it keeps switching over to the dvd function after 30 seconds or so. It's really irritating. i had a dvd get stuck in their. I took it apart and got the dvd out, put it back together and now it just keeps blinking "Please Wait." Do i have to get a new receiver? If so, is there one that is compatible that would allow me to use the Wireless IR? sorry about all the questions.
Posted by andrew85662 on
1 Related Answer
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: sony universal remote will not operate sony dream system
Solution is to buy Sony original remote for DAV-FR10W system from Sony Accessories Store under following part number..
147869811 RM-SP350 REMOTE CONTROL
Posted on Feb 05, 2009
When I watch tv, I get a squealing noise, but when I watch a dvd, I don't get the squealing through the surround sound, also when I listen to a dvd through the surround sound I don't get the s
R U getting 'feedback'?i.e. if the speakers on the TV and your external speakers are pushing the same 'sound' towards each other there could be feedback.
Oct 31, 2012 | Sony Televison & Video
Hi all, I hope someone out there can help me. Recently bought a new Samsung 46" LCD, I also have a Samsung BluRay player and HD Recorder in one, also have a PS3 and finally the Sony DAV-IS10. ...
It's unclear where the sound is emanating or where it is lost in this scenario or even the type of connection you're using to carry it.
It almost sounds like you're using the TV for sound or it's in the audio path. The sound from any high end source should be processed by the SONY DAV as close to its original device as possible and not unnecessarily patched through the TV.
The TV only NEEDS Video. High-end Audio is wasted on it.
The symptom sounds suspiciously like a loss of data from the source to the Sony DAV.
Please clarify or establish that this does or does not happen without using the remote. Sometimes remote commands are heeded by unintended devices. Try to Pause/Play sequence using front panel buttons on the unidentified Samsung BluRay to eliminate that possibility.
http://www.retrevo.com/support/Sony-DAV-IS10-Home-Theater-Systems-manual/id/2771ag604/t/2/
Observe the indicators on the Sony for any clues when the problem occurs.
Sep 24, 2011 | Sony DAV-IS10 System
No sound from sony dav-fr10w front speakers back surround works fine
First thing to check is the simple solution. Make sure you have the positive and negative hooked up correctly and also make sure that the wire ends are bared enough and that you have good clean contact in the snap terminal.
Jun 13, 2011 | Sony DAV-FR10W System
Getting a loud hum only from video function.
Check your connections. Chances are you may have crossed the RED video cable and the RED audio cable.
Feb 26, 2011 | Sony DAV-FR10W System
I want to set up my dav-fr10w to 'interlace' option so i can play the dvd's on my tv, but it's set to 'progressive' right now and the instruction manual doesn't give the specific information to change it....
To cancel Progressive scan output or to change output to interlace signal format, follow these steps..
1- Select DVD by pressing Function button on unit.
2- While holding down |<< (review) button, press Function button on unit.
This will change output signal to interlace/ composite video output from yellow pin/ S-Video.
Hope this info will help you.
Thanks.
Feb 05, 2010 | Sony DAV-FR10W System
I changed some video imput and now i cant see anything, only audio
1. Press FUNCTION repetedly until "DVD" appears in the front panel display.
2. While holding down rewind botton, press FUNCTION.
The output signal is changed to interlace format.
Apr 23, 2009 | Sony DAV-FR10W System
55HDX99 TV with Sony DAV-HDX500
Connect RCA Red-White audio cable to INPUT of DAV-HDX500 and hook it to TV AUDIO OUT pins at back of TV.
Now select INPUT in DAV-HDX500 to get TV sound in Sony system speakers.
Apr 19, 2009 | Televison & Video
Surround sound to work with sky+
hi yes it is....
wot u need to do is.....our red and white audio leads go from sky box to dvd box...we then put our dvd player onto video 1 using function button on remote
hope this helps
Feb 20, 2009 | Sony DAV-S300 System
Sony universal remote will not operate sony dream system
Feb 05, 2009 | Sony DAV-FR10W System
Connecting and recording sony hdtv, rdr-hx780 recorder,sony dream system
I have the same system, except for the TV, I have a project (that part doesn't matter).
From your Sat. go straight to your AV receiver
Again from you Sat. (all of the AV outputs are all live), go out from either 1 or 2 and go to your recorder Line 1 in.
From you AV receiver go to your TV.
All you have to do is hit record and you will record whichever channel you are on. I am having difficulty getting it set up as a PVR, but will figure it out sooner or later.
Hope this helped.
Oct 20, 2008 | Sony RDR-GX300 DVD Recorder
Sony DAV-FR10W System Logo
70 people viewed this question
Top Sony Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
