Computers & Internet Logo
Text changes to very large size all by itself
Posted by rudewolfster on
Anonymous
    New Friend:
...try to change your screen resolution of your desktop, just click this site to checkout the procedure on how you adjust the screen resolution of your desktop
http://www.petri.co.il/quickly-change-screen-resolution-in-windows-7.htm
Posted on Sep 12, 2011
Change text size
There's a button immediately to the right of the space bar marked with a large and a small 'A' - that's what you use for increasing/decreasing font size on the screen
1helpful
Sir i need large font on nokia e63 text msg and plain back ground
Hello and Welcome to FixYa!
To change the font size and to make it large for your Nokia e63. Follow the given steps:
Go To Menu >> Settings >> General >> Personalization Settings >> Now to change the text size Select "Display">> Font Size
Now select it as large if you want to see your text in large font.
For plain background just use the theme which has plain background or have white color in its background
Any more confusion, queries or for further assistance, I am here to help.
I hope this solution helps you
Thank you for using FixYa! Keep Visiting
The text size on my computer is too small. I can't figure out how to increase it. Please help
1. Right-click the Desktop and select Properties.
2. Save the current screen settings so if you're unhappy with the results, you can back the changes out. Select the Themes tab, click Save As, and enter the name Original Display Settings. Click OK.
3. Select the Appearance tab, change the Font Size drop-down to Large Fonts, and click Apply to view the new text size. The text in the dialog won't change but the desktop and Start menu will. You can also try the Extra Large Fonts setting.
4. You can also click Advanced, select individual elements of the Windows display, and change their sizes, although this is more difficult to do and the results are less rewarding.
5. If want to back out all of the changes you made, go back to the Themes tab, open the Theme drop-down, select the entry that says Original Display Settings Without "(Modified)", and clickOK.
6helpful
4answers
How to change text size to be larger
This depends upon what program you are running.
If you mean the Internet, you can change the view settings on most browsers by zooming in (go to "View" in your toolbar).
If it's a Microsoft application like "Word" or "Excel", you can increase the font size or the magnification of the document - again, from the toolbar.
Print is so small I cannot read it. How do I make the print larger?
the size is determined by the document itself...If you click on preview on files ..you will see how large they will be ..In this window ..click on shrink to fit..if you wan to print it that way ..or ..on the document itself ..change the font's size ...This will probably lead to split it in 2 sheets if the new size will not fit one page
if you are printing from a test doc..just change teh font ..if you operate on word..select the whole written text ..and change the size in the font bar
Windows XP text size is too small. How do I make it largerr?
Click on your Desktop with the right mouse button and select Properties from the Shortcut menu that appears. In the Properties window, click on the Appearance tab. At the bottom of the Appearance tab you will see "Font size:" click on that drop-down menu and you can select Normal, Large Fonts, or Extra-Large Fonts. This is how you change the size of the text that is specific to Windows.
To change the size of the text in Internet Explorer, open up Internet Explorer and find the View menu (it should be near the top left of the screen) click on View and in the menu that pops down, hover your mouse over Text Size so the menu will pop out to the right, here you can select Smallest, Smaller, Normal, Large, Larger, and Largest.
If you would like to increase the size of everything in Internet Explorer, you can hover over Zoom in the View pop down menu and change how much you are zoomed in, this will increase everything for you!
I hope this helps! If not, please comment back and let us know!
1helpful
Change text size while reading an internet sight with a windows 7 laptop
Enter on a page that has text. Then from the top-right menu, click on Page menu and watch down to the Text Size. You have some options like Smallest, smaller, medium, large, very large. Choose the desired.
9helpful
My impression's text size is very large and i can't figure out how to change the font size
While you have a text message open, press the up and down arrows on the side of the phone to change the text size (same buttons used to control device volume and picture zoom).
19helpful
I have the samsung impression SGH A877. The text
go to your inbox. then open a message and on the volume key just push it like if your going to turn the volume up. the volume key changes the size of font
73helpful
Text msg font size suddenly extra large, how to reduce size
use the volume key and act like your turning the volume down and the text size will go down.
Marvin
Marvin
