Question about Brother HL-2040 Laser Printer
I have error light on. Computer won't print. I just bought the printer and it printed just fine twice. Then I turned off the power when I did not use it. When I tried to print again. the error light is blinking.
Posted by rdcroft on
Dave King
  • 1,606 Answers
The error light that is blinking is actually blinking out a error code. In the back of your manual under troubleshooting there should be a list.
On a printer this new about the only error you should see is a paper jam. IF anything else is wrong I'd just put it in the box and take it back. Rarely do you see something fail this new these days. It happens but not that much.
Once you look up the error code you will know what the problem is. It could be a cable unplugged or a paper jam etc. I can;t see it being serious.
Posted on Sep 11, 2011
My Star TSP600 Thermal Printer is displaying a flashing Error light. Power light on, new roll of paper loaded correctly, self-test was ineffective - nothing printed. What's my next step?
i know you stated you put the paper in correctlyin the printer but if the thermal reactive side of the paper is not facing the print head the thermal paper won't print on the wrong side of the paper. it will load into the printer and seem ok but the heat on the wrong side of the paper will not react and show any writing. Can you try turning the paper over in the printer feed holder so the other side of the paper faces the print head and give it another test .
Jun 21, 2016 | Star Micronics TSP600 Thermal Printer
HP C6280 will not print self test diagnostic
Do you have an Anti-Virus program installed on your PC? If so, can you try and disable it before you print.
for more help visit CBR Tech Solutions
Mar 13, 2013 | HP C6280 All-in-One Printer
Two red light are blinking and show general error
Hi. My epson T50 printer is flashing together two orange lights showing general error, have reset ink pad with software but still the same problem. Any ideas would be great. Thanks Jim
Mar 13, 2012 | Epson T50 InkJet Printer
Computer won't detect printer
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/nJ7AgN. Select your operating system, download and execute the file.
Feb 10, 2012 | Lexmark X1290 All-In-One InkJet Printer
The black ink on my Brother DCP-130C won't print and it's a brand new ink cartridge. I thought it was a defected cartridge so I bought another one, same thing. The other 3 colours print ok though....
I have the same problem. Everything on the printer is working just fine. It'll do a test page just fine, so everything's working right. The %$^ thing just won't print. It makes noise like it's printing when you give it a print job, but it spits out blank pages.
Sep 08, 2011 | Brother DCP-130C InkJet Printer
Prints color badly won"t stay
Hi w0rtm,
To correct this issue you need to clean the print head. Please follow the steps below.
1. Press the "Power" button to turn the printer on. Wait for the printer to fall silent, indicating it has finished all of its warm up.
2. Load letter size plain paper in the printer's input tray if none is present. Hold down the "Resume" button until the printer's power light flashes once, and then let go of the "Resume" button.
3. Wait for the printer's power light to stop flashing, indicating the printer has finished cleaning the print head. Print a nozzle check sheet by holding down the printer's "Resume" button until the power light flashes twice.
4. Examine the nozzle check printout, looking for missing or broken lines in any of the sections. If you see problems with the printout, run the printer's cleaning program again and then print another nozzle check pattern.
If this does not work, please try these.
1. Turn on the printer.
2. Click the "Start" button in the lower-left corner of your computer's desktop. Click "Control Panel." Choose "Printers and other Hardware." Select "Printers and Faxes."
3. Double-click the "Canon i550" icon. Click "File" in the main menu, scroll down and click "Printing Preferences." Hit the "Maintenance" tab.
4. Click the "Cleaning" button. Select "All colors" to be cleaned and click "Execute."
5. Click the "OK" button.
6. Print a sample page and examine whether the quality has improved.
7. If the quality has not improved, repeat Steps 2 and 3. Click the "Deep Cleaning" button this time. Select "All colors" to be cleaned and click "Execute." Click the "OK" button.
If still encountering the same issue, please uninstall and reinstall the unit's driver.
Hope it helps.
Thank you for using FixYa.
Aug 21, 2011 | Canon BubbleJet i560 InkJet Printer
Why won't my printer print after I installed the software? It says its ready but nothing will print
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
Aug 18, 2011 | Lexmark PhotoJet Z705 InkJet Printer
My Canon iP90 has been working perfectly but now won't work at all. Nothing. Not a bleep. The green light's on and I've done all the utility checks and they're fine. I've tried turning...
Hi.
If you had done utility check and they are fine, had you try printing on a stand alone not using a computer. if you can print on a stand alone, there is no problem on the hardware side of the printer because u were able to print on a stand alone. you can focus now on the software side by uninstalling and re installing the driver of the printer and that should work.
Jun 10, 2011 | Canon PIXMA iP90 Mobile Printer
My HP deskjet 2050 all-in-one printer only shoots out blank paper and won't print. It used to say there was no paper in it, which there was. It scans & prints just fine - just won't print...
Any error messages on the printer digital screen or the desktop? I take it the "The ink is fine" means that there is ink in the cartridges!
Try a test print via the Control Panel> Printers and Faxes> properties > Print test page.
May 31, 2011 | HP PSC 2210 All-In-One InkJet Printer
My Dell V505 printer won't print documents from the computer, when I press print the printer prints a page of dash's and ticks. there is ink in the cartridges. i've disconnected the power....
Turn the printer off.
Disconnect the AC power.
On your computer, click Start
Click Control Panel
Click Printers
Select the Dell Printer
Uninstall it
Restart your computer
Turn the printer on
Allow the computer to reinstall the device-device for the printer.
Print a test page.
May 09, 2011 | Dell AllinOne Multifunctional (v515w)...
Brother HL-2040 Laser Printer Logo
377 people viewed this question
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Ed
Ed
