Question about Integra Audio Players & Recorders
SOURCE: Denon AVR-1804 6.1 Channels Audio Problem
Make sure the input setting is set to 'Auto' while on those channels and not Analog.
Posted on Jan 20, 2008
SOURCE: Left channel out
There are NO mechanical pots on the system. The "pots" for volume are a special bitsequence comparator, and the signal for the gain on the amp is a modulated matrix signal.
The most common problem for this kind of amps are the safety-thermal switch... They are normally located really close to the output for the speakers. Normally gray or black boxes (30x10x40mm). Flick your finger on them with volume at 9 o'clock...
If you can hear a click, and the sound appear again you've found the sollution.
NOTE! Hazardous currents are present inside the cabinet, mind your fingers, arms and other bodyparts.
Posted on Jan 23, 2008
SOURCE: Pioneer VSX-D903S
just try prologic mode no tv uses 3 ch nomore ok and turn on ch a speakers only
Posted on Jan 29, 2008
SOURCE: Yamaha RX-V800 - No audio on left and right channels
make sure the (a) speakers are switched on,this may be a switch on the front panel or in the main set up menu.
hope this helps.
cable guy.
Posted on Jun 04, 2008
SOURCE: Onkyo receiver TX-DS696
If you get sound on direct mode say from dvd but no sound when you go to dolby make sure you have the right input selected by pressing the digitat input button on the front of the amp,ie if dvd optical out is pluged into amp optical input 1 select this on amp then set audio to prologic2.DVDs through this input will decode to dolby digital/dts.
hope this helps.
CABLE GUY.
Posted on Jun 29, 2008
Mar 29, 2014 | RCA Onkyo Integra Dtr-4.6 Av Receiver Wrat
Feb 02, 2014 | Integra DTR-5.1 Receiver
Aug 24, 2013 | Integra DTR 5.6 Multi Media Amp
May 05, 2013 | Integra DTR-9.1 7.1 Channels Receiver
May 17, 2012 | Integra Audio Players & Recorders
Sep 01, 2011 | LG Audio Players & Recorders
Mar 01, 2010 | Integra DTR-5.1 Receiver
Jun 30, 2009 | Integra DTR-5.2 Receiver
Jan 28, 2009 | Toshiba MD13M1 13 in. TV/DVD Combo
Jan 17, 2009 | Integra DTR-9.1 7.1 Channels Receiver
95 people viewed this question
