Question about Gateway P-6860FX Notebook
My laptop screen went very dark, I can barely make out whats on the screen but I know its working. What can I do to fix this situation on my gateway p-6860fx pc notebook?
Posted by josue_fernan on
Curtis Sewell
  • Gateway Master
  • 7,482 Answers
Hi josue fernan...
You need to see if your laptop lcd screen is faulty and/or the lcd inverer is faulty.
1....Test the lcd screen:
Hook your laptop to an outside monitor and then start your laptop normally...if the picture on the external monitor is good, then your lcd screen is bad.
2....Backlight Faulty: If the monitor is still as dark like your lcd screen on the laptop then it could be the backlight that is faulty.
Please take time to rate me thumbs up
LCD Backlight and Screen Replacements:
http://www.laptopsman.info/0-Gateway-lcd-1.html
LCD Screen replacement:
http://www.screentekinc.com/Gateway_P-6860FX--17-inch--1440x900-wxgaplus-laptop-lcd-screen.shtml
Posted on Sep 11, 2011
Screen began flashing then went dark
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Gateway 450ROG screen went dark
Try using a can of compressed air and blowing out all the nooks and cranies. I did this and it worked for mine. Haven't had a problem since doing this. Let me know if you need more help.
2helpful
2answers
Screen went almost completely dark, can barely see at all.
I had a similar problem with an HP DV2000 notebook computer. Here's the solution for the HP model DV2040TX: Problem identified and FIXED. Not the screen, not the screen power supply. The problem was the micro-switch within the right-hand-side screen hinge. This switch turns off the screen when you close the lid of the notebook - probably to prevent overheating. The switch had failed mechanically (technical term: "fallen to bits"). As a low-cost fix, I have unscrewed the main casing including the screws inside the battery compartment, removed the silver panel covering the speakers, flicked the switch "ON" using a jewellers' screwdriver, and removed the small metal tongue that is operated by a cam on the hinge. Thus, the switch is PERMANENTLY ON. Computer operates normally, shuts down normally using Windows. Just need to be aware not to close the lid without shutting down the computer beforehand. Hope this helps you. All the best, OzKluger
LCD went dark
hook it up to another monitor then control panel then display see i8f something was changed in there
otherwise your screen may have gone but it's only two years old
what were you doing when you lost your screen
2answers
This is a hardware failure of the LCD back-light or a loose connection which requires partial disassembly to verify. Most likely it will require an LCD replacement. If you have an external monitor you can connect it to the video output so that you can see.
MY GATEWAY LAPTOP SCREEN WENT BLACK AFTER 20 MIN OR MORE
Look for cracks in the hinges. It is a big problem with the Gateway 7330GZ.
2answers
Replacing lcd
sounds like you left one connection off.... recheck the lamps
Robert
2answers
Not powering up
sound like the power connection may have broken therefore not allowing the unit to switch on or charge.Do any lights flicker when you plug it in?
Replacement part should do it
Problem with laptop screen
you reinstall your laptop........your OS
2answers
Laptop screen.
I think you should bring it to the computer shop. If the spill got inside your laptop, it will be risky to remove the laptop parts and clean it all by yourself.
Gateway P-6860FX Notebook Logo
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Michael Thomas
Michael Thomas
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
