Question about Yakima Bug Jogger Stroller
We have a bent axle and worn tire on a Yakima beetle jogging stroller. We need a new axle wheel assembly.
Posted by jlw3477 on
1 Related Answer
Anonymous
SOURCE: Folding the stroller
There are two latches/triggers. one on each side, under the handle bar behind the canopy. pull up on these and the stroller will fold down.
Posted on Jun 21, 2008
Chicco 3WD Tech rear wheel needed
Try jogging stroller its easy to Swiveling front wheel & maneuverability. Locks forward for increased stability when jogging or if the terrain turns tough.
Mar 06, 2013 | Chicco 3WD Tech - Canarie Stroller
Needing a part for Safetech Triple Jogging Stroller
It really depends on why you need this stroller. Ill start off by saying I have 5 strollers and 2 kids (4 months and 3.5 years). We spend half the year in Europe and there we have the Bugaboo Chameleon (great for city living but not practical for suburbs) and the Baby Jogger City Mini GT for traveling to other countries. We used the Maclaren quest for a while but found that the cobblestone and uneven grounds in Europe made it tough for our daughter to sleep so now the Maclaren just stays in the trunk for quick grocery runs. We also have the Bob Ironman for running for when we are in the States. My husband and I run on average of 15-30 miles a week on paved roads and trails and we love the Bob. Problem now is we have two children. My daughter is old enough where we don't need a double for everyday as we have the buggy board for the Bugaboo and that works fine. HOWEVER we are very active and we got tired of taking turns running with one child while the other waits. My daughter can't run mileage of course and even trail runs /walks are too strenuous for a toddler to walk. We needed a double for this reason. Locally we don't have these strollers so I ordered both. I love both my Baby jogger City mini GT and Bob Ironman so I wasn't sure if the Summit Double or Bob Double is what I needed. Brief comparison
1- I like the canopy on the Baby Jogger better than the Bob. It's the same coverage just sturdier.
2- the foot rest on the summit is really short. My daughters feet were dangling off the side bc she simply didn't know where to put them
3- the Bob tends to sag in the middle when both children are inside. Not the seat portion but the backrest. This was not an issue on the Baby Jogger.
4- the baby jogger is really short length wise. It makes it great for turns but I was worried if I took it on hills or trail runs that it would tip backwards. The Bob is much longer (and slimmer BTW) which also gives my daughter a place to rest her feet.
5- handbrake. I really wanted one since I'm used to my ironman. The Baby Jogger has it and the Bob does not (even though Bob is coming out with a double in July 2014 with an adjustable handle and handbrake but I needed the stroller ASAP and couldn't wait).
Long story short - we returned the summit and kept the Bob. The only reason why I'm not giving this a five star rating is because I miss having a handbrake. For running, I needed the durability and ruggedness of the Bob. I never write reviews but I figured perhaps this can help someone with the same criteria as I did without having to return one stroller back for $80. Arghhhhhhh
https://myhealthshoponline.com/all-product/the-best-jogging-stroller/
/uploadswith image
Jun 15, 2010 | SafeTech Triple Jogging Stroller
Hi I have the Schwinn M3 Jog Stroller and it has a slight pull to the right. Can you tell me how to fix it?
Is the each wheel on straight and tight?
If so, spin each wheel with the tire facing you and see if you notice any wobbling or warping effect. It's possible that either the axle of the wheel is bent or the spoke/rim is not true.
If the wheels have spoke nipples that can be adjusted, you may need to take it to a bicycle shop to see if they can true the wheel or otherwise it'll need to be replaced unfortunately.
Nov 07, 2009 | InSTEP Schwinn Titanium M3 Jogger Stroller
Foot rest for a Schwinn jogging stroller
Schwinn and InStep are two of the leading brands for Jogging Strollers. Inline with their products are the Juvenile Sports, Bicycle Child Trailers and Jogging Strollers suitable for kids and infants.
Usually the frames, tubes, tires, wheels, fabric and hardware are replaceable on our strollers. Different models might have different parts that can be replaced. You can order replacement parts by calling the Customer Service Department at 800-242-6110 and speaking with a representative.
You can also check out this web site for more places and information on parts: http://www.1st-babies.com/joggers_strollers_trailers/Where_Do_I_Get_Parts_For_A_Schwinn_Jogging_Stroller.shtml
Nov 02, 2009 | Schwinn Runner ST Jogging Jogger Stroller
Tire blew on putting a little air in.
if you have run a long way your tyres should have been worn out even if you fill the air within preferred psi.so i suggest you to buy new tyres ..but remember everytime you change the tyre be sure the wheels are tightened at preferred torque since uneven torques are also responsible for easy worn outs.
May 23, 2009 | Baby Gear
Wheel alignment
Just take it to your local bike shop. They should be able to fix it. The wheels/tires are basically small bicycle wheels/tires.
Mar 29, 2007 | Baby Trend Expedition Double Jogger
Yakima Bug Jogger Stroller Logo
43 people viewed this question
Top Yakima Baby Gear Experts
Marvin
Marvin
Paul Carew
john h
Are you a Yakima Baby Gear Expert? Answer questions, earn points and help others
