Question about Keurig B60 Coffee Maker
I have a Keurig special Edition with the XL reservoir purchased in April 2011. I use water purified with a reverse osmosis system. The amount of coffee produced is inconsisent from cup to cup. sometimes it makes a full cup, sometimes not. It could make a partial cup on one brewing and the very next cup will be full and vice versa. I typically refill the reservoir with a pitcher, not by removing it.
Posted by mnm2871 on
D. Floyd Kolb
  • Keurig Master
  • 43,501 Answers
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Sep 11, 2011
  • Havyk Apr 25, 2012
    Dude, you're commenting the same thing on every post about Keurigs not working, but the link is dead...nothing comes up when I click it.
    Does anyone else have the answer to this?
  • D. Floyd Kolb
    D. Floyd Kolb Apr 29, 2012
    This fixya site has been run into the ground....the deal was that I would write tips and they would pay when the tips were read.....they renigged...I deleted the tip.....email me at [email protected] and I will send you the tip. Sad to see the ownership of Fixya screwing the guys that helped them make it a great site....
EShell
    New Friend:
    Problem Solver:
  • 6 Answers
Very very common problem with these coffee makers. Try de scaling as said in the manual. If that doesn't work you just have to get a new one. These units are not well made they are pieces of junk. We bought a Cusinart KCup brewer it works ok for now
Posted on Jun 09, 2013
What is the difference between a water purifier and a water filter?
The main difference between the two is that water filters only remove parasites and bacteria from water, while purifiers removes these as well as potential viruses.
Aug 26, 2012 | Brita Camping, Backpacking & Hiking
Do I need a water purifier?
I personally live in a city and I'm using a water purifier, I suggest you to buy one if you also live in a city in order to avoid contaminations in your tank due to low quality water. The only time you don't need to use a water purifier is when you live in a town with fresh water of high quality.
Aug 02, 2012 | Fish
How does a water purifier work?
A water purifier works through the process of reverse osmosis. Water purifiers cleanse water by passing it through a series of filters. This helps remove large amounts of contaminants and other harmful chemicals
Jul 09, 2012 | Camping, Backpacking & Hiking
Is prime the same as descale
I knew the paperclip trick, I tried the air shot to reverse the flow of water. After running Vinegar and water through and letting sit overnight. I tried the air blast then make a cup, another blast X 4....though I get a good flow through the K-cup area, I still only get 2/3 cup of water.
Jan 15, 2012 | Keurig Special Edition B60 Coffee Maker
Coffee brewing slow and makes a sound like it is loosing suction
If you haven't done so already, try running a cup or two of household (white) vinegar through it. Just pour room temperature vinegar into the fill reservoir. Follow with two full amounts of distilled water (not tap water) to clear the vinegar out. Then try to use ONLY distilled water or at least water that's been through a mineral filter. Calcium buildup from running tapwater through the small heating tube is what clogs up most coffee makers.
BTW, not all "purified" water sold in stores is distilled. It must be STEAM distilled to be true "distilled" water. Wal-Mart carries it. Other stores do, as well, but make sure the bottle actually says something like "steam distilled" on the label, otherwise it's probably only run through a filter. "Purified" water may also be treated by reverse osmosis, which removes some mineral content, but this is NOT steam distillation, the process which removes (almost) all of any mineral contaminant.
Apr 27, 2009 | Keurig B60 Coffee Maker
Coffee grinds on K cup holder
try removing the K-cup holder and inspecting the bottom hole opening. This is where the bottom of the K-cup holder would go through. Sometimes grounds can rest on that edge and fall into the coffee. I hope I could help!
Feb 15, 2009 | Keurig Special Edition B60 Coffee Maker
Keurig B60 Coffee Maker Logo
1,113 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Vincent G
Vincent G
Paul Bade
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
