Question about Apple iPhone Smartphone
What to do when iphone doesn't turn on - Apple iPhone Smartphone
Posted by ezzy_km on
Michael J.
  • 443 Answers
If it won't turn on. Meaning it doesn't turn on turn on. The phone is dead and gone.
If the phone turns on but sticks at the apple logo, that means it needs a restore/update.
If the phone turns on and stick at the usb/apple logos. That means it needs to be restored.
To restore or update. You need to use itunes. If the phone is bricked and dead, dead... Then you need to get a new phone
Posted on Sep 11, 2011
My Smart satarter doesn't work because I upgraded the iPhone 5s to iPhone 6 plus. I redoenloaded the viper app but it doesn't work?
There can be problems when iOS is upgraded. Get the latest version with the latest bug fixes. Watch the Viper app for version changes and download it when it gets updated. Check the Viper support web site:
http://www.viper.com/Support/
Jan 06, 2015 | Remote Start System
IPhone when in dock doesn't ring on messages or calls.
When your iPhone is plugged into the dock be sure that your volume is turned on loud and also that the dock is on. if your iPhone is plugged into the dock but the dock isn't on your iPhone is not going to ring out loud.
Jan 20, 2013 | Apple iPhone 5
My iphone cannot turn on.....i tried all the solution in this forum and still my iphone does not turn on....pls help.
Have you tested it with another battery?
Make sure the battery is good.
Make sure the battery is connected to the iphone properly. That is, check the battery terminal.
If the above doesn't solve the problem, then it means the iphone has developed a power problem.
Regards.
Jan 16, 2012 | Apple iPhone Smartphone
Iphone 3gs screen problem
If the problem is consistent in other windows besides strictly the keyboard it is possible that the capacitive touch panel is defective or has been damaged.
Dec 12, 2011 | Apple iPhone 3G
Is utube and iphone ginoogle the same sign
utube doesn't exist, and ginoogle isn't a company.
the YouTube app on the iPhone is the official YouTube iphone application. Yes, it's the real Youtube
Nov 21, 2011 | Apple iPhone 3G
There is sound on touching the icons but it doesn't work/ slide to unlock button also doesn't function
There is no sound touching icons. Never has been. There is only sound sliding the lock unless someone turns it off.
As for the lock not working. Chances are your screen is malfuncitoning
Oct 09, 2011 | Apple iPhone Smartphone
WHEN I TRY TO SEE RECENT CALL HISTORY THE I PHONE 3 GS REVERTS TO THE HOME SCREEN. IS THERE ANY WAY OF RESOLVING THIS?
hello,ensure you are not clicking on the key wrongly,i would advice you put the phone off and on back to see if the problem stops.if it doesn't i would also advice you ensure you close any application you are not making use of.it could also be as a result of accumulated opening of applications. if that does not stop the problem,i would suggest you get the phone flashed by a mobile phone authorized repair engineer around you.
wish you good luck,
take care.
Jun 30, 2011 | Apple iPhone 3G
I have had my iphone less than a week- i did not expect it to have problems so soon. .... i have iphone 2g my battery ran out now it wont recharge or turn back on? .... but it doesn't turn on, it...
If your iPhone's battery runs very far down, the iPhone won't turn on. That's because it's using its remaining battery life to preserve your data and settings.So, your iPhone could be refusing to turn on because its battery doesn't have enough juice. In that case, plug your iPhone into a wall charger or into your computer (plug it directly into the computer; some USB ports on keyboards don't have enough power to charge iPhones). Let it sit for 10-20 minutes. If it was low on battery and needed a charge, when it's got enough juice to power the screen, it will turn on and show you its charging status, starting with the red battery icon.During this process, you may also want to make sure there's no lint packed into your cable or the iPhone's dock connector. This isn't a hugely common problem, but a lot of pocket lint could interfere with the iPhone getting a charge.
Jun 28, 2011 | BoxWave Corporation Apple iPhone 2G...
Apple iPhone Smartphone Logo
265 people viewed this question
Top Apple Cell Phones Experts
Marvin
Marvin
sandyp4ever
sandyp4ever
Level 1 Expert
Matthew Boulden
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
