Question about Master Lock 5400d: Portable Select Access Key Storage Lock
Reset combination of this 1500iD. - Master Lock 5400d: Portable Select Access Key Storage Lock
Posted by btcuyos on
Chris Crockford
    New Friend:
  • 28 Answers
Here is the page:
http://www.masterlock.com/pdfs/5400D_Instructions_Sheet.pdf
Posted on Sep 11, 2011
3 Related Answers
Anonymous
SOURCE: Forgot combination to 1500id master lock how do I
from my understanding, you don't.  Cut the lock and buy another (and don't forget this time).
Posted on Jul 31, 2010
Anonymous
  • 28 Answers
SOURCE: My friends were messing around
Make your dumb friends find the code or buy you a new lock.
there is not trick to it... it'll have to be done by trial and error...
Sorry for your troubles.
Posted on Sep 01, 2010
snowghost1
chris wheeler
  • 784 Answers
SOURCE: i for got my combination to my 1500iD master lock
if you have totally forgotten the combo, then the only way to figure out the combo is to progress the combo -- to do this you will start from 0000 and then 0001,0002,0003,0004 etc.. all the way through until you hit the right numbers and the lock opens, ( make sure you try and open the lock at every new number ). a 4 digit combo usually takes about 1 1/2 to 2 hours to go through all the numbers. what will help in this progression process is if you can at least remember one of the numbers or better yet, remember two of the numbers.
some locksmith shops do have special tools ( readers ) that might be able to read the wheels and figure out the combo for you --- call around and ask some of the lock shops in your area if they have the ability to read the lock for you,, but if they can't - then you are back to square one ( progression ).
hope this helps,
c...
Posted on Jan 26, 2011
Where do i store my combination
I am not aware of a "Lock Box" or "storage" capability on FixYa.
If you want storage capability for free...
Google free online storage.
  1. Googledrive.com
  2. box.com
  3. dropbox.com
  4. iCloud.com
  5. evernote.com
  6. bitcasa.com
These are just a few available that are very good.
Nov 14, 2014 | Master 1500ID Combination Padlock
I lost the combination to my speed dial master lock and it is in the locked position. How do I open it and create a new code?
It's not easy to fix this problem, because these locks do not shim open and it's not obvious how a person could figure out the old combo. I was able to loosen and remove the security screws, disassemble mine and repair it. They are very tricky to reassemble and it took me hours to find the spring that was out of position. The root problem was the lock did not clear when the shackle was pushed in. Until I figured that out, it would take up to 30 tries to get it open. The security screws are Metric - so you can replace them with regular screws until you get it working. If you do open the case, there are a lot of small parts inside, including a bunch of springs.
Aug 18, 2014 | Master 1500ID Combination Padlock
How do I get it back open when it won't open to the combination I gave it?
Make sure you push the shackle down firmly to clear the lock and try the combo again. It is possible to open it by trial and error, but not easy. I have removed the security screws and repaired one, but it was tricky to reassemble. The problem with mine was a spring that slipped out of position and the lock wouldn't reset correctly. There are a lot of parts inside, so chances of getting it to work correctly are not good unless you're really good with complex mechanisms and puzzles.
Aug 05, 2014 | Master 1500ID Combination Padlock
I set a code in the master lock speed dial 1500id, and it will not open. I cannot reset the code and do not know how to get this open. I have read the other suggestions and nothing has worked yet. Anyone...
Try 2 options:
1. just squeeze the shackle twice and pull it out. This is in case you forgot to enter new combination.
2, Make the 2 combination together, the old and the new as one sequence. This in case you forgot to squeeze the shackle before enter new combination
Ity
Sep 06, 2011 | Office Equipment & Supplies
I for got my combination to my 1500iD master lock what do i do
hope this helps,
c...
Jan 26, 2011 | Master Lock 5400d: Portable Select Access...
My friends were messing around with my 1500ID lock and changed the combination, then closed it. How can I reset it and change the combination?
Aug 31, 2010 | Master Lock 5400d: Portable Select Access...
Master Lock 5400d: Portable Select Access Key Storage Lock Logo
1,033 people viewed this question
Top Master Lock Locks & Locksmithing Experts
Marvin
Marvin
Lawrence Oravetz
Kelley Hopper
Are you a Master Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
