Question about Danby DWC283BLS Wine Cooler
MHello. We have a DWC283BLS-1 wine cooler. I got it from my aunt who had it in storage. The digital numbers on the front keep staying at 83 & 83. Every time I press the buttons to make the number lower, it just beeps, flashes & goes back to the same numbers. It is not cooling at all. What shall I do?
Posted by kimtee on
James Gettemy
    Sergeant:
  • 232 Answers
It sounds like the Freon leaked down. That always happens when they are stored. Find a community college that has refrigeration classes and maybe they will look at it for you.
Posted on Dec 17, 2017
5 Related Answers
OhioSteve
SOURCE: Noisy Wine Fridge
I had the same problem, and found it to be as RonLew described. In our case it was the internal fan in the upper rear section of the fridge. Apparently, since it is mounted so close to the rear panel, the sound seems to amplify from the back. Anyway, a replacement fan was only $3.71 direct from Danby, but I did have to pay 7.99 for shipping. Also, there is a fair amount of disassembly and re-assembly needed, which might be challenging for those who don't typically make their own repairs. Once removed, the only thing I could find wrong with our old fan was that the shaft was very loose in the unit, which may have indicated a bad bearing.
Posted on Jun 13, 2009
Dennis Boxerman
  • 1303 Answers
SOURCE: we have a danby dwc283bls wine cooler that no
that's always a possibility but not always the case. The thermostat may not be cycling correctly or set wrong. The condenser could be dirty or if there is a fan, it may not be running. Freeze ups can also cause an "Out of temp." condition. Check it out.
Posted on Apr 15, 2010
jim george
  • 6 Answers
SOURCE: Dandy wine cooler dwc283bls-1 has
temperature sensor open
Posted on Oct 27, 2010
SOURCE: code E4 on dandy wine
We had that problem in 2007, about 10 months after buying it from Costco. It was under warranty so the tech came and changed both sensors. It's worked fine until Feb 11. Now, the lower section ran so cold it froze some bottles. I am looking for a solution to that problem.
Posted on Mar 04, 2011
ZJLimited
ZJ Limited
  • 17970 Answers
SOURCE: I have the Danby Model
Are you tray to "reset" the unit; disconnected power few minutes (five before to reconnected again).
If the problem come on again, try to set the temp manually accordign the User Guide.
Keep us updated.
Posted on Apr 28, 2011
Fans stopped working
go to sears parts direct and enter your DWC283BLS you will have the plan and number parts you need
Mar 15, 2014 | Danby DWC283BLS Wine Cooler
F230073 p c card
try there http://www.searspartsdirect.com/partsdirect/part-model/Danby-Parts/Wine-beverage-cooler-Parts/Model-DWC283BLS/3055/0169000/50031952/00001?blt=06&prst=0&shdMod=DWC283BLS
Dec 16, 2013 | Danby DWC283BLS Wine Cooler
Need parts diagram for dwc283bls-1
http://www.searspartsdirect.com/partsdirect/part-model/Danby-Parts/Wine-beverage-cooler-Parts/Model-DWC283BLS/3055/0169000?pathTaken=&prst=0&shdMod=DWC283BLS
Dec 25, 2012 | Danby DWC283BLS Wine Cooler
Looking for the mother board for the DWC283BLS Wine Cooler
go at sears go to this address http://www.searspartsdirect.com/partsdirect/index.action?pop=flush
and good luck with the repair
May 15, 2011 | Danby DWC283BLS Wine Cooler
Danby DWC283BLS has condensation inside the unit.
wine coolers have no means of draining the condensate inside them,use silica gel(1/2 pint)to keep the inside dry(remember to dry it out when condensate happens again)
Jul 16, 2010 | Danby DWC283BLS Wine Cooler
Danby DWC283BLS Wine Cooler Logo
198 people viewed this question
Top Danby Furniture Experts
Dennis Boxerman
jdthefixer
jasbo
jasbo
Are you a Danby Furniture Expert? Answer questions, earn points and help others
