Hello
The door switch is also in line with this circuit.Check that first.Door switch needs to close for anything to work.It provides power to control board as well.
Check for voltage at door switch single black wire to make sure you didn't blow circuit breaker.
If ok then check continuity of switch with power OFF. there should be continuity between black terminals. Also check continuity between white terminals . If thats ok , then make sure the switch is physically closing. Really suspecting the switch here.
Hope this was helpful
The
most common causes of this problem are a defective water inlet valve or
a stuck float switch. The float switch sits under the dish racks and
sends a shut-off signal to the dishwasher when the water level is high
enough. Make sure you only use a Maytag-compatible replacement if you
have to change out your dishwasher's float switch or water inlet valve.
Difficulty: Moderate
Instructions
Things You'll Need:
