Question about LG 50PB4D 50 in. Plasma HDTV
I'm getting lag on this plasma TV. If I play my AMP audio and tv Audio at the same time, it's like an echo sound playing. Even when you turn off the amp and leave the tv audio on, you can tell the video or sound is lagging. I tried plugging in a regular dvd player with your basic a/v cables, same thing. Any fixes? Does warranty cover lag? My warranty expires in 12 days. any help would be greatly appreciated!! Thanks!
Posted by superstar28 on
jeff5may32
  • LG Master
  • 1,258 Answers
Audio lag is normal for many TV's.
Posted on Jul 04, 2017
5 Related Answers
Coldcut
Karl Whisenand
  • 1554 Answers
SOURCE: LG 47" LCD TV - 47LC7DF Clicking Noise
the old saying is that any issues will likely show up in the 1st 3 days if you run it for 72 hrs. if it dosent fail then it will last.
other than going to the show room and seeing if their unit does the same.
they will likely want to send a service guy to check it out and decide for himself.
Posted on Feb 25, 2008
Anonymous
SOURCE: LG 42PC5D Sound Lag
I have the same issue. The audio seems to be okay through an antenna input, but not through an outside source input. There is about a 100ms audio lag, and the video is processed about 50ms faster than normal, making a total audio lag of about 150ms. To fight this I run any audio source through a separate receiver/stereo. The problem is now cut back down to the 50ms video lag difference. I am going to try putting video signals through the receiver too, maybe to induce some lag there and even things out even more.. Using the digital output does not help any (I've tried it), any audio is still processed by the tv and therefore slowed down.
Posted on May 11, 2008
Anonymous
SOURCE: LG DK 8621P DVD Player only play the audio (no video out)
how can off the progressive scan in my LG DVD player model 8680?
Posted on Dec 27, 2008
Anonymous
  • 7 Answers
SOURCE: LG 42PX4DV - HDMI Audio / PC Audio IN problem
one quick fix you can try. plug in the HDMI cable, slect a digital audio sound output from the sound settings on your machine, then leave it connected and restart it. It just might work.
Posted on Aug 05, 2009
Anonymous
SOURCE: LG DP781 DVD player
Souds like a cable problem. First, make sure that the cable you are using is the right cable-it should be a multi-signal cable. Look for a colored circle of insulation on the metal end that separates the tip of the connector from the bottom of it. You might even have more than two sections if it is a stereo jack. If you are sure you have the right jack/cable, then it's possible the wire carrying the video signal could be damaged. If it's not a cable issue, it's a jack issue, so look for damage on the device's output jack.
Posted on Apr 02, 2010
How do I connect a cd player to both a tv and an audio amplifier so Ican play either Cd's or DVDs?
Does the TV have a line audio outpot (red and white jack)? If so feed the amplifier input from there.
Dec 23, 2012 | NAD C372 Amplifier
My ilive itp180b sound bar won't play sound from my lg plasma tv
Sound issues and answersa short list:
sound on set or a box muted or turned down?
speakers inside the set (see menu) switchedon or off?
internal/external switch somewhere in or on back of set?
Clearly it could be a audio problem (a model number?) but explore all here thatyou have not already done--make sure theremote set to TV and look for a button on it marked MTS and if there cycle it.
You can also determine if same trouble when you play a DVD.
Apr 02, 2012 | LG Televison & Video
Sony BRAVIA KDL-40V2500 audio not working
I would Google the model number carefully for "problems" "no sound" and usually this set will display some kind of error code===it may even have a hard reset to try===service manuals are available on the net/web to allow you to see how the sound circuit is set up etc.
Mar 29, 2012 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
I cant get the tv to go through the surround sound i can only get the surround sound to play when its a dvd playing do i need another wire to go from the dvd player or will it not work no matter what plz...
If you've got the Audio Input Source set as TV-Audio and it won't play as Surround Sound then you'll need to connect the Audio Out from your TV (if it has one?) to the Audio AUX IN on your LH-T360SE and change the Audio Input Source to AUX.
Jun 04, 2011 | LG LH-T360SE Theater System
Have an RCA RTB 1023, blue rays have played fine until I played a movie last night and the voices echoed? What causes that??
A common mistake with this type of setup can make for a frustrating solution, until you realize how silly and simple it is.. I'm going to take a stab in the dark and say you have this system connected to your tv through an HDMI cable, correct? If so, please nod! Now that you've just finished nodding your head up and down at a computer screen, have a little chuckle and now we'll continue! :-P Your HDMI cable is special because not only does it deliver magnificent picture to your tv, it also carries the sound from your player to your tv as well as playing through your surround sound speakers! So here is where the fun comes in, depending on what you may have been watching on your tv that particular day, the volume level is bound to fluctuate, because of a little know fact that not all tv channels use the same sound output level as others... Ooo you've learned something new, pat yourself on the back and here is your simple solution. Next time your watch a dvd on your system turn the volume on your tv up up up, and down down down, some times there is a slight lag from the audio being played on your tv speakers than on your surround speakers. So when in doubt, just turn your tv speakers all the way down! :) enjoy
Jan 10, 2011 | RCA RTB1100 Theater System
RX-V465 Yamaha Reciver we can get picture but no sound w/PS3
Check HDMI Sound settings:
Enter Setup menu via remote, then Func. Setup / HDMI / Audio. You can choose from Amp (sound will be played via Yamaha), TV (sound will go straight via HDMI out to your TV and not play on Yamaha) and Amp+TV (Yamaha will play the sound and also pass it to the TV).
Also what is your source? DVD or some network player? For example Yamaha cannot decode audio in AAC or other computer formats, so be sure to change the audio settings of your player to output PCM and not raw/bitstream.
Mar 26, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
Plasma tv
the only way to do this if your tv doese not have a audio out is to run a HIFI VCR as the tuner through the amp and then from the amp to the tv this will give you the same result.
Nov 28, 2007 | Philips 50PF9630A 50 in. Plasma Television
LG 42PC5D Sound Lag
Turn the volume on the TV all the way down. Its becasuse you have the sound come from both sources. its kinda fun to play with.
Sep 24, 2007 | LG 42PC5D Television
Open Questions:
See all LG 50PB4D 50 in. Plasma HDTV Questions
LG 50PB4D 50 in. Plasma HDTV Logo
67 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
