Whirlpool GBD307PDS Electric Double Oven Logo
Posted on Sep 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Whirlpool Double Oven Model GBD307PDS09 - After pre-heating, display fades in brightness until it becomes totally black. No indications of time or status of oven. Display totally black. After turning off, display returns with clock time indication.
  • 1 more comment
  • longj380 Sep 10, 2011
    As I mentioned the display will come back when oven is turned off and cooled down.
    When the display returns we can turn oven back on and the display will stay bright for the
    duration of baking cycle. The display may fade again when a new cycle is started.
    The display does not stay off or black. It does return to normal indications.
    Do you still believe the display needs rebuilding ?
  • longj380 Sep 11, 2011
    Macmarkus,
    After sending you the second comment, I found the Service Technicians schematics and troubleshooting steps supplied by Whirlpool. I did check the primary and secondary winding resistances and both were not measuing expected values. Primary measured 58 ohms, should have measured 75 to 95 ohms. Secondary measured 2.5 ohms, should have measured < 1 ohm. I think I will change the transformer first, before changing display. The transformer value are off just enough that makes me suspect a problem. Thanks for your help.
    Phil
    Both solutions were valuable. I performed service technican checks and found enough information to diagnose the problem. Thanks.
Anonymous
Level 3:
  • Whirlpool Master 2,605 Answers
  • Posted on Sep 10, 2011
Anonymous
Whirlpool Master
Level 3:
Answers
2605
Questions
0
Helped
1119156
Points
11111
Hello, welcome to FixYa.
I understand based on your post you have the Whirlpool GBD307PDS09 double oven with the "fading display" scenario, correct ?
The issue with these displays is they can lose their intensity over time because of the fluorescent tube technology they use, hence the only remedy is to rebuild the control/display kit...the display only is not available.
**For the display/timer your only option (the only one I'm aware of)... it's the one I recommend as opposed to replacing the entire unit, is to have the existing display and control rebuilt...the down side is this will require the parts to be removed and sent away**
Here you'll find all the info pertaining to this option by clicking on the link's I've provided below. The first is the Whirlpool visitors site, the second is a list of timer numbers they do (yours is 8302319)
http://www.corecentricsolutions.com/published/whirlpoolappliancepartsrepair
http://www.corecentricsolutions.com/WP_Parts_List.html
Hope this helps move you forward. Let me know if I can assist you further and good luck.
Regards,
Macmarkus :)
  • Anonymous Sep 10, 2011
    Hello again,
    thank you for replying, I'm glad you did. I think I may have misunderstood...slightly. While these display's do have a habit of fading, it may simply be the transformer if it only occurs during heating sessions.
    I would slide the oven out far enough so you can access the top of the oven and test the transformer and follow the wires back to the clock/display to insure they are secure...heck for what it's worth (usually around $25) I'd change the transformer since as you describe it, (fails when hot...sounds like an open winding) it is quite likely the culprit. (if it test ok it is the display though)
    Below is a good link for explaining it's principles and testing the transformer...starting at about 2:30 of the video will show how to test the primary and secondary windings, but you watch the entire video if you like.
    http://www.youtube.com/watch?v=QqaxkGcEz...
    Let me know how it goes or if you need any further assistance.
    **Please insure the power is off before servicing though...safety first**
    Regards,
    Macmarkus :)
I have a Whirlpool electric acubake wall mounted double oven which is 15 yrs old. Most of the time the digital controls work fine. Twice now the digital display has gone totally dark. An hour or so...
Anonymous, we're sorry to learn that your Oven isn't heating. We will be glad to further review your concerns. Please email us at [email protected] with your name, contact number, address, model and serial number.
My whirlpool double oven accubake GBD307PDS09 display went blank!!!! HELP!
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty. GBD RBD Whirlpool Oven Problems Causes and Solutions
2answers
My whirlpool double oven accubake GBD307PDS09 display went blank then beeped. The oven does not turn on but when I tried to turn it on just to test it, it beeped once and then three short beeps. I have...
Hello Diana,
Their are a few things that should be checked. I know its going to be tough to check on a built in double wall oven but one thing that needs to be checked is if their is 240 volts ac entering the oven(i know the breaker is ok) but the connection at the back of the oven can burn,then the proper voltage wont enter the oven.
Another thing is a high limit thermostat thats inside of the control panel,need to checkif it has blown.
Last thing i can think to check is if 120 volts is at the clock, if not 120vac that explains the blank display
We just purchased a Kenmore Elite double oven (model # C970-600131); we don't like the intensity of the neon clock light; too bright to read the time from the next room; is it possible to turn this...
no it is pre-set and not adjustable.
perhaps some auto-tint over the display will help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
1helpful
2answers
No heat! Lights work, timer etc - everything "appears" to be working but there is no heat!
Probably your heating element has failed, dependant on appliance the element can be found in the oven itself at the back behind a panel that normally has a couple of screws holding the panel in place. reasonably easy to fit yourself and not very costly.
Hope this helps
2helpful
4answers
Fading digital display on Thermador SC302ZS Double Oven
when the display is fading it has to be changed part number 492071 that is for a double oven display
Display problem
you can replace the display, however you have to take the face apart
1helpful
2answers
I fixed my problem by disconnecting the control board, cleaning all the contact points (including the ribbon cable) with alcohol and reconnecting everything as tight as possible.
I did notice that one of the contacts had become very corroded, so I scrubbed this one for a while. Prior to this I had done some selective unplugging and replugging (ribbon cable in particular) to no avail (each of these attempts powered on to beeping and no display).
Not a fancy solution, but it did work!
Top Whirlpool Ovens Experts
ZJ Limited
ZJ Limited
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
