It is under the upper heating element panel.
The reset button should be located on the top heater controller. (red button). Sometimes each thermostat has a separate controller but most of the time the top acts as the master over-current protection. Remove the gray cover for the top heating element to get access. Make sure turn off the circuit breaker feeding the water heater before you remove the cover...you never know how good of a job the last person who worked on the unit did at insuring all the wires were properly secured and connections insulated.
If the overload trips again...you may have one or more bad elements.
Good-luck,
Sundriver
