Question about Tappan Ovens
SOURCE: whirlpool oven caught fire while cleaning
just scrape out the residue and clean it again.
Posted on Dec 12, 2008
SOURCE: Wiring diagram for Whirlpool Oven
you can get it her at this site.
http://www.partadvantage.com/store/categories/wp/RM770PXBQ2
Posted on Dec 17, 2008
SOURCE: I need to change my oven ignitor and I need a diagram
Here's a diagram of the oven along with the Oven Ignitor (Part #19 on the diagram) and the Broiler Ignitor, (Part #26 on the diagram). They are located behind the gas deflectors located at the top and bottom inside the oven compartment, accessible from inside the oven, but you'll need to remove the rear panel at the outside back of the stove to disconnect the terminals tha supply voltage to the ignitors.
Be sure to turn the breaker off and/or unplug the range from the 220V-AC outlet first.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=FGF353BADB&productCategoryId=0124002&brandId=1428&modelName=FRIGIDAIRE-GAS-RANGE---5995274411&diagramPageId=00003&componentDescription=BURNER&documentId=Y2702738&backToLink=Return%20to%20Sub%20Components%20list
Hope this helps you complete your repair. Best Regards!
Posted on Jul 31, 2009
SOURCE: I have a Frigidaire Gallery
Got a frigidaire gallery pro-series oven model #FGF379WECS the pervious owner had propane gas but i have natural gas. is there any way of switching ithe oven from propane to natural without buying a converter kit?
Posted on Oct 04, 2009
SOURCE: Oven wiring diagram or help?
I suggest you post this under Inglis to have a better chance of having an answer
Posted on Jan 26, 2010
Oct 11, 2018 | Ovens
Aug 04, 2011 | Ovens
Go to www.ukwhitegoods.co.uk you will need the model number and serial number and place an enquiry. They will get back to you.
hope this is helpful
John
Jun 05, 2011 | Ovens
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Mar 07, 2011 | Tappan Ovens
Nov 24, 2017 | Ovens
Jun 04, 2010 | Ovens
May 11, 2010 | Hotpoint SY21 Style Line Gas Single Oven
Nov 21, 2009 | Ovens
Apr 20, 2008 | Stoves Premier 900GRa Gas Double Oven
228 people viewed this question
