SOURCE: pri master hard disk: S.M.A.R.T. command failed
there is problem with hard drive kindly replace it.
have a nice day dont forget to rate pls.
SOURCE: S.M.A.R.T Command failed
It means that the hard disk SMART monitoring system has detected problems serious enough to warn you of the growing possibility of hard disk failure. Sometimes a drive will last quite awhile after this first notification, but there is a good chance of imminent failure, in minutes, hours, days, or weeks. You should immediately look into installing a replacement drive.
You should immediately copy any important data off the drive, perform full backups, and limit use of it.
If you can install drives yourself, a new hard disk (especially Seagates) usually come with software to clone your existing drive to the new drive. Otherwise, a repair shop will be able to do it for you.
I recommend also purchasing a drive enclosure for your old drive. For whatever life it still has, it will be a good backup of your system.
SOURCE: "primary master harddisk S.M.A.R.T Command failed , press F4 to resume"
More information is posted here: http://www.fixya.com/support/t286025-s_m_r_t_command_failed
It is recommended to do a hard drive backup as soon as possible. And even replace that hard drive as soon as possible. Before full physical failure.
SOURCE: When I was trying to
this is a warning your hard drive is about to fail
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
hope this helps
a. Click Start, type services.msc and hit ENTER.
b. Locate Windows Time.
c. Right-click and select Restart. make sure there are no disks in cd floppy usb drives Test all leads that attach to your hard drive including electrical extensions IDE,SATA the leads from your ((MOTHERBOARD TO YOUR HARD DRIVE)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat ribbon 40 pin IDE it will be the fist to fail
there can be a number of things that can halt the boot process
bios settings not right
bad or faulty leads
faulty bootmanger
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs data and power to travel through every working device and to continue its cycle and to have an end so any faulty leads will end up with a computer error
also make sure you have set it boot from you hard drive in BIOS
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter make sure your first boot device is set to your hard drive press escape then press f10 to save to cmos to restart
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
hope it helps
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test or replace all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard)) drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
? single or master :::::
master with slave ::'::
???????????????? slave? :::':
note the plastic jumper is
note the plastic jumper is ' located at the rear of the hard drive next to the IDE/SATA lead/s
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
hope this helps
