Dishwashers Logo
Posted on Sep 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Salt reservoir has water in it so how do i put salt in there.
Anonymous
Level 3:
Master:
  • Master 577 Answers
  • Posted on Sep 10, 2011
Anonymous
Master
Level 3:
Master:
Answers
577
Questions
0
Helped
218759
Points
1089
Hello, to what are referring to here. To put salt in your dishwasher? Or are trying to convey that you have water softener? You don't put salt in your dishwasher but you do with soft water conditioner. GB...stewbison
5 Related Answers
A
Anonymous
  • Posted on Jan 22, 2008
SOURCE: Water in salt reservoir
I've had the same dishwasher for 2 years now and always had water in the salt compartment. Don't know if this is normal but disn't seem to be a problem til now. Just fill with salt as if it was empty.
douglas smith
  • 1462 Answers
  • Posted on Mar 30, 2007
SOURCE: the salt light keeps burning
the salt light is done by a reed switch operated by a float in the salty water. float may be stuck - give softener (where you put in the salt) a tap and also stir the water inside the softener. i assume you have put in enough salt. its not a serious fault
Anonymous
  • 640 Answers
  • Posted on Jan 06, 2008
SOURCE: miele G893
you should have a dispenser on the door to add salt,regardless get c.l.r. calcium lime rust remover from a supermarket,lowes,home depot.put a cup in the unit ,run for 15 minutes and then put a cup in again.let the unit complete its cycle.if you still smell the odor repeat until its gone.you could also use baking soda,flour or vinegar.
douglas smith
  • 1462 Answers
  • Posted on Sep 18, 2008
SOURCE: adding salt in dishwasher
that is what is supposed to happen
Anonymous
  • 144 Answers
  • Posted on Mar 27, 2009
SOURCE: dont know where to put the salt and how salt indicator goes off
it should have a dispenser in the bottom of the tub you just need to unscrew the lid
What is the meaning of the red arrow light on my Defy DDW236 Dishwasher? I filled with salt yesterday and had to refill again today which is also strange so that light is back on too
On other Defy dishwashers, the red arrow indicates End of Cycle. Thus your dishes should be clean and ready to be removed from the dishwasher. See page 14 the manual for the DDW170 here: https://www.newappliances.co.za/uploads/documents/DOWNLOAD%20MANUAL%20DDW170.pdf . On page 6, the manual states that the add salt indicator can glow for an extended period after you add salt. This is due to the time needed to dissolve the water softener salt in 1 liter of water. Do not add more salt than the reservoir can hold (2 Kg for the DDW170).
I hope this helps.
(Note: if the salt reservoir was dry, you need to add water before adding the water softener salt.)
Oct 14, 2020 • Dishwashers
Hi my kleenmaid silent system think it's a dw2 the salt button is flashing you turn it on it goes to start then stops we cleaned it all out and fix the problem once before but this time nothing works. I'm...
If water is soft in your area you can ignore the salt indicator light and operate the dishwasher without adding regenerating salt. However, you need to ensure the salt reservoir is filled with water to the brim. So add water into the reservoir and then put the cap back on.
Dec 26, 2014 • Dishwashers
How can I drain a water softener
Are you talking about the resin bed or the salt reservoir?
Salt Reservoir ~ Remove as much salt as possible then dump the water out.
Resin Bed ~ You do not want to remove the water from this unit. Disconnect it from the water supply and discharge and cap it off.
2answers
Do you need to put salt in the dishwasher. If using tablets detergent ...where to put it ?
A lot of dishwashers do not have salt dispensers. If it does, the salt is added to a container which has a lid on the base (floor) on the inside under the bottom basket. Unscrew the lid and add the salt. Use normal pool salt. It is the same as "special dishwasher salt" that you pay a lot for. When full, the salt will last for 12 to 18 months. Most machines that have a salt container, also have a warning light on the panel to let you know it needs refilling. Dishwasher tablets do not add salt to the machine. Make sure you wipe up any salt that you may have spilt on the base of the machine, it will stain or rust the cabinet.
Sep 25, 2014 • Dishwashers
Salt reservoir
Yes. The water flows throught the reservoir regardless. The only difference is the salt indicator in the front dash will not lit.
1helpful
Our water is soft and does not require salt. how do we stop the red light
I think it might depend on the model # and it should be in your manual.
Example for a G858 SCVI plus instructions (without pictures) are;
Bypassing the salt indicator
If your water is soft (below 8 gr/gal) the
salt reservoir should not be filled with
salt. The indicator will remain lit and
should be disregarded or bypassed.
Remove the salt reservoir cap.
Looking into the salt reservoir, you will
see the top of the float chamber on the
right hand side, a.
Using a screwdriver, carefully pivot
the float chamber towards the center
of the reservoir.
Using needle nose pliers, pull the
cap, b, off of the float chamber, and
remove the float, c.
Replace the float chamber cap, push
the chamber back into its upright position,
and replace the salt reservoir cap.
The "Salt" indicator should no longer be
lit.
DISHES COMING OUT WHITE PUT IN SALT BUT NO DIFFERENCE
Not sure what model dishwasher you are having.
If you have hard water and are using water softener then you may have to adjust the setting of the softener.
If your dishwasher has separate brine reservoir to control hard water then brine pump may not be letting enough water go through the reservoir to disolve the salt.
Make sure the rinse aid has not entered into the softener reservoir.
Clean the dishes coming with white residue using vinegar solution.
Mar 05, 2010 • Dishwashers
2helpful
My salt light won't stop flashing even though its full of salt. Its a Hotpoint FDW60. Ive tried turning off and an at the mains.
I think I have the answer.
On Yahoo Answers Blue Rizla Girl put up the idea that the sensor is some form of hydrometer. (i.e. floats in salty water sinks if not salty enough)
Based on this thought I postulated that the sensor is some form of hydrometer float in a tube with perhaps an optical sensor.
If this is correct why is it not working?
Is it because the float is stuck at the bottom of the tube, perhaps by some food debris? If so how can we fix it?
This is what I did on my Hotpoint FWD60:-
I took the salt filler cap off. There was no salt in the reservoir as it has been a problem for months, and I was only refilling it when dishes were not coming clean.
I poured 2 litres of hot water into the salt reservoir.
I then put the empty machine on the intensive 65 degree wash, half load and with the reservoir cap still OFF.
When finished I filled up with salt and HEY PRESTO the salt light is OFF!!!!
Just hope it stays that way until the reservoir really needs refilling.
While I was down on my hands and knees I took the opportunity to clean the filters in the sump. They do get full of bits!
I also flushed the sump by dashing a couple of cups of hot water into it and then bailing it out with a small yoghurt pot. I repeated this until the water in the yoghurt pot and the sump no longer had any signs of bits in them. (Dashing = vigorously pour)
I was amazed at how many bits I got out, especially considering I had given the machine a good clean in the past 6 weeks.
I even got part of a paper label!
So there we have it, try it out and report back.
AcmeUK
Matsui mf160 dishwasher salt indicator will no go out
AcmeUK
Apr 20, 2009 • Dishwashers
10helpful
Salt indicator light comes on?
Check the instructions which are freely available from www.miele.co.uk or the relevant site for your country. Browse to the current models and you should find the PDF for your model. For non-current models, instructions are under the link "Customer Support".
In general, the instructions are as follows:
If the water in your area is very soft and constantly lower than 0.7 mmol/l (4 °d) you do not need to add dishwasher salt. The water softener must, however, still be programmed to correspond to the water hardness level in your area. (The salt indicator light will still come on, but should be ignored).
Important: Before filling the salt reservoir with dishwasher salt for the first time, you must fill it with approx. 2 litres of water to enable the salt to dissolve. Once the dishwasher has been used, there is always sufficient water in the reservoir.
Inadvertently filling the salt reservoir with powder or liquid dishwasher detergent always leads to serious damage to the water softener. Make sure you have picked up the correct packet of dishwasher salt before filling the salt reservoir!
Only use special coarse grained dishwasher salt for reactivation. Do not use other salts such as cooking salt, agricultural grade or gritting salt. These may contain insoluble additives which can impair the functioning of the water softener.
To refill:
* Remove the lower basket and unscrew the salt reservoir cap.
* Fill the reservoir with approx. 2 litres of water (first use).
* Place the funnel provided over the salt reservoir and carefully fill with salt until the reservoir is full. The salt reservoir holds approx. 2 kg of salt depending on the brand used.
As the salt reservoir is filled, displaced water will overflow.
* Clean any excess salt from around the reservoir opening and then screw the cap on again firmly.
* Run the "Pre-wash" programme immediately to remove any traces of salt water from the cabinet.
For the Miele, the salt reservoir is usually under the bottom basket, the cap is usually grey in colour. [Only the latest models have the refill cap in the door itself].
You should be able to find dishwasher salt just about anywhere, I've even found it in Malaysia, sold at good ol' Tesco!! Brands of salt include Calgonit (Finish) & Somat.
Top Dishwashers Experts
Mike Cairns
Mike Cairns
