This issue usually occurs when the vehicle is between 60 - 70 mph. There is no official solution to this issue, it should have been a Ford recall, as this fault is dangerous.
There is a known malfunction in the fly by wire system that is suspected to be the cause of this system failure. The throttle body assembly gets replaced when this occurs as a possible solution to the problem. Check
the connections on the 2 tps sensors first before assuming the
replacement is necessary.
buy a universal remote. The navigation cd can be downloaded from(you need utorrent software to download it, simply google it) http://www.picktorrent.com/torrents/c1/saudi-arabia-bmw-navigation-cd/ or buy it from You can buy it directly from Navteq by following this link to your gps unit...
Hold your finger on the power button for 10 seconds, you will hear a beep and it will set the display settings to default. And you should now see your ps3.
