Question about Motorola TLKR T5 Two Way Radio
I have a pair of Motorola TLKR-T3 walkie talkies. One of them is either not receiving or the other is not transmitting, I don't know which, but they are now useless. HELP Please.
Posted by stewart_pert on
happy2all
    New Friend:
  • 16 Answers
For this problem contact your mobile service provider.......
Posted on Sep 10, 2011
TLKR T60 and Amytel AW1010T. Is there any way to pair all four together? (Walkie Talkie)
Amytel and Motorola may not use the same numbers for their frequencies. You need the actual manual for both models and you cross check the actual numbers. Do this for the Codes or Tone section also. This happened a lot in early days of consumer radios and still happens with chinese imports. Best of luck.
Aug 28, 2017 | Motorola Radio Communications
Portable motorola gp 340 can receive but cannot transmit
Don't know your capabilities but if it were me I would open the phone and check the contacts for transmit button. Sometimes contacts get corroded and need cleaning or it just may be no connection at all and a adjustment of the contacts will resolve the issue.
Mar 10, 2014 | Motorola Walkie Talkies 2-Way Radio
My Motorola TLKR-T3 won't work properly. Both transmitters-receivers work only in monitor mode. I have downloaded the manual and I made with high accuracy the step to set the devices properly, but nothing...
i had them for 5 years.
and they were just great.
in 6 months the one after the other did the same thing.
motorola is trying to tell us that we have to buy a new pair.
they sould know that i will not buy motorola again
Apr 01, 2011 | Motorola TLKR T5 Two Way Radio
One of my tlkr-t3 walkie talkie's will not recieve.
They worked fine the first time we tried them out. Then they were put away for several weeks, and when they've been switched on, one now doesn't send. I checked this by the other putting in scan mode but it doesn't stop scanning at the channel it is assumed to send with. I tried all the channels for sending but neither one is detected. The other way around, so the first one in scanning mode, the 2nd in send mode, works fine (the scanning stops at the channel of the sending one, as expected).
So my conclusion is, that one doesn't send.
I interchanged the (fresh) batteries, but this doesn;t change.
So what could be the problem?
Feb 27, 2010 | Motorola Radio Communications
Motorola TLKR T3 communication problem
svp dite moi comment les refaire marcher car il y en a un qui recoit tout et l'autre rien du tou svp aider moi
Oct 04, 2009 | Motorola Talkabout T5720 (7 Channels)...
Motorola TLKR T5  Two Way Radio Logo
1,925 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Ekse
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
