Televison & Video Logo
Posted on Sep 10, 2011
I cannot turn TV off from remote. It makes the picture go out but red light is still on. Have to unplug the TV to turn it all the way off.
  • rainworld_eh Sep 10, 2011
    Yes on/off on front pannel but it will not shut the TV off. Have to unplug the TV.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 10, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
100
Points
Red light stays on because tv is in standby mode when switched off by the remote, should be an on/off switch on the tv body somewhere
Proscan LED TV Will power up the red standby light & standby on amber when turned on but does not show picture or sound unless I unplug and replug over
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
3helpful
2answers
Neither of my remotes (1 came with the television when I bought it and the other is a remote for my cable box that is programmed for the TV too) are working on my 47LG50 television But the remotes have...
Tries take both remotes controls pushes all the funsctions butons one by one on the front of a turn on Digital Camera,see if u will able to see all the INFER RED signal white light will flashing on the Digital Camera viewing screen.To make sure both the remotes are working and all the buttons are have INFER RED light signal out.Tries pushes all the tv manual buttons on the tv side too see if it is funsctioning too.If all these work testing work,than take some rubbing alchahol put on a rag clean the INFER RED sensors signals on the tv an the cable box by the tv power light LED indications lights.Tries these steps,make sure tv manual control tv side panel work and both remotes works and clean both INFER RED sensors on cable box and tv make it work better.Unplug the cable box for an hour for it to reboot and updating it softwares.Replug the cable box and now tries the tv remote or cable remote again,should functions now.
LG 42 LCD no sound or picture
Did anyone find out the solution for this??????? I have the exact same problem with my LG 32 LCD. I only had it for a year and a half, and the green light blinks a few times and it shows no picture. Not even a red light when the tv is off. The same thing happened a couple weeks ago and by some miracle it started working again.
Panasonic 32 inch LCD TV will not turn on-red light flashing
its not hard to replace the bulb and you can go to any tv shop and have them order it.youll need to give them the make and model number off the back of the tv so they know what to order
3helpful
Sony Trinitron Color TV KV-35V65 - No Picture, red light stand/by timer flashing
A reset won't fix this. The standby light should be blinking a repeated count with a 3 second pause inbetween. Post that count here. That will indicate the circuit/condition that is preventing the set from turning on.
Thanks,
Dan
Panasonic model# PT-47WX547 is not working
how many times does the LED blink ? Thats a error code.
Powers on by itself
TV worked FINE for the past 2 yrs---this morning we woke up and the screen is totally BLACK! No sound..nothing. REmote doesn't do anything to the TV. Red light says ON unless we unplug it. Remote won't turn off the TV.
Any advise? Picture tube??
Worked great w/out any problems until we woke up today!
Thanks,
Tina
2answers
My 32in sdtv red power light,no pic no sound
your problem is likely to be in horizontal section of tv. please take the help of skilled tech. it is not a major problem but as you know that it is a high voltage device.
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
