How do I reset my WIFI password of AT&T Router?
In the event that you use AT&T for your Internet administration, you presumably have an AT&T switch/modem as your equipment association point for the administration. This switch associates with every one of the gadgets in your home that you need to attach to the Internet, including your PCs, workstations, tablets, cell phones, savvy TVs, and other associated gadgets.
While the AT&T establishment professional apparently left your hardware all arrangement and designed appropriately, complete with a default secret key, you might need to change that secret word to one based on your very own preference or make other security-related changes. Changing your AT&T secret key to something increasingly verifies can shield your home a system from undesirable visitors.
Follow the below steps to reset AT&T Router Password:
Start by going to http://192.168.1.254
Note: you may be required to enter your Device Access Code in order to continue. The default Device Access Code can be found on the side of your gateway (this is not the same as your Wi-Fi password).
Go to Settings > LAN > Wi-Fi
Scroll down to User Network
Changes can be made to your Wi-Fi name under Network Name (SSID)
Changes can be made to your password under Wi-Fi Password
Save all changes made to your device
Right now, I will tell you the best way to roll out these improvements to your AT&T gear and increment the security of your remote system. It'll likewise tell you the best way to modify some other significant settings on your AT&T switch.
Source: How do I reset my WIFI password of AT&T Router
Look for mini button around or at the back of your router and reset by holding for around 30 seconds.And try using default password like admin or sometimes leave it blank. If its not work look for the brand of your router and google it for default username and password. Hope this will help you.
Do not worry you just reset your wifi router it will present on the router there is a image :-
