Question about Akai PT4298HD Rear Projection Television
GHi, My red timer light keeps coming on when I turn the tv on. It keeps blinking about ten times and then shuts off. The tv doesn't turn on anymore? Just looks like there is a timer that was turned on and I can't turn it off in order to get my tv back on? How can this be fixed?
Posted by seniorhealth on
Ikenye Henry
    Sergeant:
    Champion:
  • 209 Answers
Turn the TV on, then use the red button on the remote to power the TV.Then check the timer and turn it off. Thank you for using Fixya.
Posted on Sep 10, 2011
  • aaliyahw429 Sep 18, 2011
    All's that did was to make the red light stop blinking. How does that help the tv to come back on?
Sony wega tv kp 51ws520 keeps turning off after the standby red light blinks 10x's
problem with str ic need replacement has an internal short need a tech to do it
Jul 08, 2013 | Televison & Video
How do I change the clock on my sony bravia tv?
Press the HOME button on the remote. You want to find the CLOCK/TIMERS section. Navigate to SETTINGS. Use the arrow keys to select item. Use the arrow keys to set current time. Press RETURN to display the confirmation. Select YES to save the changes.
Sep 04, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
Feb 14, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Tv wont come on and a red light is blinking. I have a Sony Wide screen projection TV model kp-46wt520
Can you unplug the TV for about 15 seconds, and then plug back in and watch the stand-by light. Tell me how many time the stand-by light blinks in regular intervals. If it doesn't blink at all, you need to change a fuse on the g-board. Once this is done run back through the stand-by blink light process, and more troubleshooting can be done if problem isn't already solved. If the stand-by light just keeps blinking with a count over ten just tell me, and I'll look for other possibilities.
Oct 25, 2009 | Sony KP-46WT520 46" Rear Projection...
No pic
alright guys...blew a bulb....fixed that. still didint work...found out it was ballast...replaced that. tv worked for a month..all the sudden hdmi input didint work id plug in my playstation and screen would turn green and say "hdmi color has been corrupted" im thinking wtf? so a week later it works fine then just turns off in middle of watching espn... comes back on an hour later...only to turn off again...it just turns black for ten seconds then just turns off and the red and green lights blink at intervals of one second....replaced a bulb..not that, same problems.......when the tv comes on for the ten minutes before it quits working the pic and sound are great i just dnt get it...is it shorting out? color wheel bad? a fan?
May 24, 2008 | Toshiba 52HM95 52" HDTV Projection...
Akai PT4298HD Rear Projection Television Logo
266 people viewed this question
Top Akai Televison & Video Experts
Marvin
Marvin
matt martin
matt martin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
