Akai PT4298HD Rear Projection Television Logo
Posted on Sep 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i reset my akai L842ADFD - Akai PT4298HD Rear Projection Television
  • dideedi Sep 10, 2011
    Thanks. I will follow instructions and hopefully this resets it.
    thanks
Anonymous
Level 3:
  • Master 517 Answers
  • Posted on Sep 10, 2011
Anonymous
Master
Level 3:
Answers
517
Questions
0
Helped
117156
Points
1424
Good day!!
Here are the Instruction you can do to reset your tv.
  1. Check the power connections first to rule out any problems there. Unplug the power cord from television and the cable, if applicable. Wait 10 seconds, re-plug and press the "Power" button on the remote control or television control panel. If your television is not repaired, go to the next step.
  2. Reset the television. Press and hold down the "Power" button on the television control panel. Wait 10 seconds to reset the television. If your television is not repaired, go to the next step
  3. Reset the television to its factory default settings. Press the "Menu" button on the television control panel or remote control.
  4. Highlight "Installation," press "Enter" and open the "System Status" menu.
  5. Highlight "System Information" and press "Enter"
  6. Press the either "" arrow and then press "Factory Defaults" when it appears.
  7. Enter your four-digit "PIN code" or enter "0000" as your "PIN code" if you did not set it previously.
  8. Highlight the "Yes" option and then press "Enter." Wait until the television turns off -- about 10 seconds -- and then unplug the television power cord.
  9. Plug in the television power cord to complete the default factory setting process.
If the problem is still unsolved please add a comment.
Thank you for using fixya!!
  • Anonymous Sep 11, 2011
    You are very much welcome dideedi...
    Thank you too for the ratings just contact or add a comment if the problem is still unsolved.
    Have a Good day!!!!
MY AKAI TV HAS BEEN LOCKED WITH CHANNEL LOCK AND DON'T KNOW HOW TO UNLOCK IT. AND THERE IS LOGO OF M IN RIGHT SIDE CORER OF TELEVISION
Try restoring it to factory settings. I found these instructions and hopefully they'll help you to disable the channel lock problem you have -
How to Find the Reset Button on an Akai TV Techwalla com
1helpful
How do I reset my AKAI t.v.?
Go to:
· www.ehow.com/how_7465251_reset-button-akai-t...
AKAI lct3285ta will turn on, show the akai logo and then turn off
Update the firmware. It is corrupted. Do a hard reset to this set, and then check. Sometimes it might help you. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
The volume keeps resetting to 0 with out prompt on my Akai plasm
buy a new reciever, i recomend a vintage pioneer the SX1980 was the best ever made!
How to factory reset akai ds8341 camera. I see garbled images on the 2.5 inch lcd monitor
Two ways... 1. Go into the camera menu and find "reset"...follow the on-screen instructions. 2.Remove the card and battery...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...turn it on.
4helpful
Code remote akai pt46dl10
had same problem tried all kinds of universal remotes but none were compatible look online and found only logitech Harmony® 550 Advanced Universal Remote is compatible with this model akai pt46dl10 bought one now works fine and was able to reset my lamp timer with it as i just replaced it paid $65 on craigslist for remote good luck
Continuation of chat session
Hi again,
Appreciate the direct "Ask Me".
Got something for your. To reset the Akai LCT2701TD, pls try:
  • Press MENU button;
  • press < or > until "Misc" menu appears;
  • press UP or DOWN button to highlight "Default";
  • press ENTER button to confirm; unit will reset and be restored to factory defaults;
  • confirmation message will pop-up.
Looking forward to your update (or even the lack of it).
Top Akai Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
