Amana ARB2217CSR Bottom Freezer Refrigerator Logo
Question about Amana ARB2217CSR Bottom Freezer Refrigerator
My ice maker doesn't seem to be working... I pulled the fridge out to check that the lines were connected (and they are) & that there are no kinks in the lines ---- everything seems fine, but the ice machine is not "calling for" water to make ice. (The ice maker is engaged with the ice maker bar in the down position.
Posted by kflynn1215 on
Anonymous
    President:
  • 3,773 Answers
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Posted on Sep 10, 2011
1helpful
Water leaking and no water to ice maker?
pull fridge out
unplug
turn off supply faucet to ice maker
check line and fridge connection for the leak usually at the frige.
repair as necessary
turn on water
check for leaks
Mike
The ice maker doesn't work & water drips down from the freezer to underneath the vegetable crispers. It is not the plug. Is there a turn off valve on the ice maker line so that no more water can...
NOTE: This
.I'm including my article on Refrigerator Repair for your help and convenience.;
Leo Ponder
imufo2
2helpful
My ice maker isn't getting water in to make ice. I can manually pour water into the maker, let it freeze, and get the maker to get the ice out, but no water comes in. GE model GSHS5KGX. Side by side...
If it ejects theb you need to replace water valve in rear bottom of fridge(Its the part that
If its leaking same part needs replaced.The water valve at the bottom rear of fridge.
Thank you for using fixya
imufo2
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Built-in side by side. The in-freezer ice maker is not working properly. makes one row of ice every 10-2 hours. i have checked temp, water filter and water line...all is fine. had the ice maker replaced...
Leo Ponder
Please rate me if this helped.
1helpful
I have an Amana refridgerator, BRD18V13, and the ice maker stopped making ice. What's wrong?
Leo Ponder
I have a sub zero model 650 refridgerator. It is making some ice then it seems as though the water keeps dripping and it freezes up the shelves. Its like the water doesn't shut off when its suppose to...
Leo Ponder
Ice maker has stopped working.
Leo Ponder
We have a whirlpool refrigerator model number ED25PQXNN01 and the icemaker does not work...have already replaced valve and icemaker...still does not work. Please help
that model number doesn't come up?did you check the fill line that fills the ice maker to see if it's froze up?get a hair dryer and a screw driver,stick the screw driver into the fill line,you might have to remove the ice maker,if the screw driver hits ice blow the hot air into the hole and keep the screw driver in the line,the screw driver will heat up and help get the ice out.you can pull the fridge out and heat the fill line with the hair dryer on the back of the machine where the fill line connects in the back up top.if there's no ice there make sure water is coming to the fridge,also you can jump out the ice maker to manually check it to see what's happening to it,i'll look up a link and send it to you,just copy and paste it and it will show you how to jump out the ice maker and how to jump out the water valve,you'll have to pop off the front white cover of the ice maker,get a piece of wire to stick into the holes to jump it out.
2answers
Our automatic ice maker will not quit dripping in the freezer. It keeps clogging the ice maker with icicles and large blocks of ice. Essentially, it keeps "freezing over." We have defrosted it...
if it keeps filling and overflowing you have a bad water valve on the back of the fridge.the part number is WR57X10027 and the valve is around 75 dollars.first thing lift the arm or shut off the ice maker so it won't leak anymore,you're missing a few letters off of the model number so when you call your parts store give them the full model number,open the fridge door,look up on the right hand side wall up near the ceiling and give them the model number to make sure you get the correct valve,shut off the water supply to the fridge,then have the new valve next to the old valve when you remove a water line from the old valve just connect it to the new valve,do this until everything is changed out and the new valve is in place,turn on the water supply and you can check the ice maker to make sure it doesn't overflow.you can manually start the ice maker by grabbing the plastic arms of the ice maker and pull them forwards slowly until the arms start to advance on their own,you'll hear the water valve fill the ice maker and then you can watch it fill to see if the water is filling it correctly and i'm sure you'll be fine with the new water valve installed
Ice maker has stopped making ice
Check the ice maker to see if there are ice cubes in the ice maker. If so, there is a problem with the ice maker heater and / or motor. You may be able to rebuild the ice maker by replacing defective parts, but it might be easier to replace it as a whole unit instead. If there is no ice present, it is likely a problem with the ice maker water lines / solenoid.
There are usually two solenoid valves and tubing systems for these types of fridges. One actuates on demand for water whenever requested, and the other operates automatically to make ice cubes until the ice cube reservoir is full.
Carefully push/pull the fridge away from the wall.
Unplug the fridge from the outlet.
Shut off the water supply to the fridge.
Remove access cover (usually the on the bottom) from the back of the fridge. Follow the tube that comes from the top of the fridge (for the ice maker) down to the bottom of the fridge.
Inspect visually for sources of the leak on tubing and related parts. Carefully check by hand for leaks in areas not readily visible - including the back sides of all the tubing, too. There may be sharp edges that can cut if not paying attention. If a leak is found where the tubing connects to other parts, you may be able to simply remove the tube and cut it back an inch or so if there is enough slack.
It may require that some special fittings and parts be obtained to reconnect and some compression type parts are designed for single use. If this is the case, gather the parts and bring them to a local hardware store for assistance obtaining replacements.
If a solenoid valve is found to be the culprit, due to a crack, etc. a trip to an appliance parts store will be required - unless able to purchase online. Part prices can vary widely , depending on the source.
Once replacement parts have been secured, reconnect after disconnecting power & water supply lines. When satisfied with the installation, reconnect power and water lines and test.
Carefully slide the fridge back into position - taking care to not crush the power or water lines.
Dec 31, 2009 • Freezers
Top Amana Refrigerators Experts
Steve
David Shaub
Marvin
Marvin
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
