Texas Instruments TI-89 Calculator Logo
Posted on Sep 09, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My calculator is blocked: the first window with all the apps is always displayed. i can't move from an application to another and when i get off/on the piles, the calculator get on and the same bug is here. Thanks for the help; Omar
k24674
Level 3:
  • Texas Instru... Master 8,093 Answers
  • Posted on Sep 12, 2011
k24674
Level 3:
Answers
8093
Questions
0
Helped
4673399
Points
21595
The fact that the icons show on first screen is not a bug. It is a configuration setting.
Just in case some keys answer to a keypress.
Press the diamond key and the HOME key to get to the HOME screen. In Home screen press the MODE key. Use the Function keys (F1,F2,F3) to move to the last page of the configuration where you find the option Apps Desktop and toggle it to OFF. Press ENTER to save.
If that does not work (because the arrow keys) do not answer, try to RESET the calculator: Press [2nd][MEM] to open memory management then press F1 key to RESET. Try ressetting all RAM.
If more keys refuse to respond then maybe you should contact TI-cares at education.ti.com
1helpful
2answers
Calculator missing in my nokia 2690 phone
The inbuilt calculator should be in the organizer. It's kind of strange that the calculator is missing because you can't delete or move this application. Try a reset by typing *#7780# and the password is 12345. The other option is firmware update using a PC Suite.
Notefolio app not showing in my TI89
Transfer it to the calculator, if you have not done so already. If it has been installed, it should show on the AppsDesktop. To explore the desktop, use the arrow keys. You can also deactivate the AppsDesktop ON on the last page of the MODE, to have a list displayed when you press the Apps key. Once you find the NoteFolio app, select it and press ENTER. Here is how you proceed afterwards.
408bfaec-f5c9-4089-a6b4-c7517055caee.jpg 783a1491-192e-4456-bff2-413dd673ed51.jpg
9788439a-9d78-49af-a872-fb15d9f964ef.jpg bde1a278-c998-42ac-be27-f852b8ceeff9.jpg
I cannot get the calculator to graph more than one line. I've tried highlighting teh equals sign and hitting entor to make it dark but it will only highlight one equation at a time.
One of the applications Inequalz or Transfrm is still loaded in memory and it controls the graphing capabilities of the calculator. To restore control to the naative OS, proceed as follows.
Press the APPS button.
Scroll dowwn or Up to find Inequalz.
Select it and press ENTER.
A message is displayed sayin Inequal Running.
Select 2:Quit Inequal.
If the message you get is
APP CONFICT.
or Conflicting Apps
Reset the RAM to kick the applications out of memory
Will only display one graph at a time
APP CONFICT.
or Conflicting Apps
I accidentally press reset all and now all my apps are gone. I was wondering how I can restore it back to normal with all the default apps just like when I bought it. Please explain in step by step fashion...
Go to education.ti.com . Download all the applications you want from this page and install them on your calculator.
For that you will need a mini to Standard USB cable or a TI USB Silver cable.
The drivers for the cable have to be installed manually if the computer does not recognize the device.
  1. From the TI website (computer software) download TI connect and install it on the computer.
  2. Run TI Connect, and verify that it finds your calculator:
  3. In TI connect main window, click Screen Capture or Device Information, or Device Explorer.
  4. Once the calculator is correctly identified, drag an application downloaded from TI and drop it on the TI Connect main window.
  5. It will install on the calculator.
  6. After transferring two or three apps, stop to allow the calculator to defragment the memory space.
  7. Resume transferring applications.
When i click on window, there is a line, which says shaderes. How could i delete this line?
The INEQUALZ application has been executed previously and it is still in memory. To recover the usual graphing, UNINSTALL the INEQUALZ application.
To do so:
  1. Press the APPS button.
  2. Scroll Up or Down till you see INEQUALZ.
  3. Highlight it and press ENTER.
  4. In the new screen that is displayed, select the OPTION to UNINSTALL the application.
  5. Go back to Y= editor to enter functions to graph or press GRAPH if functions have already been typed in.
How can i change my language on my ti-84 plus silver addition?
  1. Use the APPS button.
  2. Use the Arrow keys to scroll down the list of applications.
  3. Find the one that corresponds to the language you want (Fran
42helpful
How do i get rid of shadeRes in my window T84
You might have activated the application called Inequalz. It solves inequations. One of its feature is the shading of solution regions and the resolution of the shading is called ShadeRes. When you press the Window function key you see the ShadeRes value before the usual window dimensions.
To get rid of the Inequalz application (kick it out of memory without removing it completely from calculator)
  1. press the Apps key.
  2. Use downArrow to put focus on Inequalz and press ENTER
  3. In the new screen that is displayed "INEQUAL RUNNING" select [2:Quit Inequal].
3helpful
2answers
Restore apps to TI-84 Plus
I am always happy to polish the apple...before I eat it. (Just joking!)
All the applications that were preloaded on your calculators are available to download freely from http://education.ti.com Use the tab Download--> Apps and software. Then select software for the TI83/TI84 Family. While you are at the site download the TI Connect, if you do not have it already. The link follows.
http://education.ti.com/educationportal/sites/US/productDetail/us_ti_connect.html You can also download the latest OS there. (Beware: while applications and programs are compatible with the TI83 and 84, the Operating systems are not.)
Install TI connect on your computer and run it to open the main Window.Then connect you calculator to a USB port and, in the TIConnect main window Click the TIDeviceInfo icon. Software will try to retrieve the info. If it does your calculator is ready to communicate with the computer.
If it tells you Device Not found , Click communication settings in same pop up window where it said Not found, and Select Device, Select Cable (USB or TIsilver cable), Select Port (USB1) and Click OK..
If you are lucky and it works, you can reinstall the OS, which can be downloaded from education.ti.com. You drag and drop the OS on the TIconnect main window. Calculator must of course be connected to computer. To install an application already downloaded to your computer, drag it to the main window of TI Connect and drop it. Keep installing, the appilcations you want.
If you have problem with TIconnect, use the calc-to-calc cable to transfer the Apps from a working calculator. You should be on Receive mode [2nd][Link] --->>Receive. (When both calculators are ready hit enter.) The other calculator must be set to Send [2nd][Link][SEND][C:Apps]. A list of Apps appears. Scroll down the list. If you want to transmit un app you press [ENTER] when the arrow reaches its line. Once an app is selected , a small square appears on the left. After the selection, Hit transmit. I suggest you transfer Apps, one after the other. Avoid selecting them all and send them all at one go.
If you want to transfer the OS of a working calculator the sending calculator must be on [2nd][Link][SEND][SendOS]. TI83Plus OS is not compatible with TI84Plus nor TI84PLUS Silver edition OS.
In addition to the preloaded applications, you can also transfer programs the same way. For a repository of TI83PLUS/TI84PLUS and TI84+ SE, go to www.ticalc.org (or com), visit the archive section of the site.
Hope it helps.
1helpful
Applications are gone except Finance
All the applications that were preloaded in your calculator are available to download freely from http://education.ti.com Use the tab Download--> Apps and software. Then select software for the TI83/TI84 Family. While you are at the site download the TI Connect, if yoy do not have it already. The link follows.
If you are lucky and it works, you can reinstall the OS, which can be downloaded from education.ti.com. You drag and drop the OS on the TIconnect main window. Calculator must of couse be connected to computer. To install an application already downloaded to you computer, drag it to the main window of TI Connect and drop it. Keep installing, the appilcations you want.
If you have problem with TIconnect, use the calc-to-calc cable to transfer the Apps on a working calculator. Yous should be on Receive mode [2nd][Link] --->>Receive. (When both calculators are ready hit enter.) The other calculator, you guessed exactly right, must be on Send [2nd][Link][SEND][C:Apps]. A list of Apps appears. Scroll down the list. If you want to transmit un app you press [ENTER] when the arrow reaches its line. Once an app is selected , a small square appears on the left. After the selection, Hit transmit. I suggest you transfer Apps, one after the other. Avoid selecting them all and send them all at one go.
Hope it helps
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
