1993 Cadillac Eldorado Logo
Posted on Sep 09, 2011
No air will blow thru the front air vents it blows air thru the back air vents and the top of the dash
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 10, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
717
Points
Is it just the hot air that wont blow, or is it both hot and cold?
  • Anonymous Oct 10, 2011
    probably the climate unit
  • Anonymous Apr 21, 2013
    its not blowing out of the dash vents or the back
1 Related Answer
Anonymous
  • 1071 Answers
  • Posted on Jul 23, 2009
SOURCE: Air conditioner is not blowing out front vents but good out back
climate unit is bad
Cadillac Seville 2007 hot or cold air won't blow thru vents blows fine in the back can hear under dash some clicking wen changing from the floor back to dash vents but nothing happening
HAVC Vent Blend Door failure, under the dash
There are several
Have to check for codes or do whatever is needed to
locate the failed ones & replace
1helpful
Left Vents blow warm/hot air when calling for cold air
Usually a sign of a faulty blend door under the dash.
The blend doors direct air thru the ac and heater core along with the upper and lower vents.
2005 ford explorer air only blows thru top vent
Usually a sign of a faulty blend door or problem with the control on the dash. The blend doors direct air thru the heater and ac then thru the selected vent outlets.
1helpful
3helpful
Blowes air throught defrost vents only
its a problem with the switching mechanism. you have to look up under the dash to see if you can see where the switching mechanism is. if you can not see it from there youll have to remove complete center dash
Aircon not blowing through dash vents
If it blows thru other vents, your air ducts may have come loose. If you don't get any cool air, your coolant is low (it evaporates during the time and below some point it will not circulate anymore). Also the aircon blower can be faulty.
1helpful
Air blows out thru the vents but just no hot air, aslo i have to hit the dash for the air to come out thru the dash vents at times.
sounds like bad acuator motor, this is what moves the door in heater box to set hot or cold air, and other motors to set air to blow thru defrost, vent or floor. good luck.
3helpful
2answers
Air blend doors do not work. Air blows from defroster vents
check or loss of vacuum to mode control switch in dash ac control. these are not blend doors, they are air flow control, a blend door controls the air temperature not where it comes out.
2helpful
2answers
Air conditioning not blowing thru the vents
Just had the same problem. It was a broken vacuum line on top of the engine. Check all vacuum hoses, and especially the one that goes to your pot. You should hear it hissing when the engine is running. If not, wiggle them around until you find one. Let me know how it goes.
Top Cadillac Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Cadillac Expert? Answer questions, earn points and help others
