Hello, So this fryer flame are orange, hey. The air intake needs to be cleaned
and the flame regulator needs to be set. Don't do your self. Have a state
certified technician HAVC clean it and set the flame. In a majority of the
States and Cities to work with Natural/LP gases. You'll need to be certified and
test and license by the state and the have permit by the city to work with gas.
We call this BY-HOYF "burn you hair off of your face" Please have a
professional do this work for you, it could cost you more than the hair on your
face. I wish you luck...GB..stewbison
Posted on Sep 09, 2011
The opening of the jets is too large. Solutions:
1. Replace the jets by a greater number that is a smaller hole. They can be up to nine jets on Frymaster fryers brand. Option 2: Remove the bronze jets and fill the holes with tin solder in common use in plumbing and drill holes. They recorded with numbers the size. the bit to be used to make the hole indicated. For example, a hole was drilled # 56 with # 56 drill bit. The correct size of hole is determined by the pressure and volume of gas, so re-drill this hole is not too difficult process. Given that the smaller sizes are equivalent to drill larger holes, the holes for natural gas range from # 54 to # 31, while propane holes ranging from # 62 to # 48. Opening experience from the smallest size using a sharp rod 1/16 "as a needle or ice pick. If natural gas or LPG Propane Butane. In no high-temperature jets for the gas outlet and not the cooled pewter melts. fully open the floodgates air. there adjustable jets, they have insert a needle to rotate open or close the hole. Always check for leaks with soapy water. My job is that for 8 years have modified fryers and ovens. I've never had accidents. Luck.
Jets in Spanish is "Espreas". Sometimes named "Boquillas" mostly in oxigeno-acetileno welding equipment.
Machine translation is very bad. Better reading in English.
