Question about Nor-Lake Refrigerators
Looking for handle model df-13-a serial 93102539 make norlake freezer
Posted by dqbroadway on
1 Related Answer
Roger Grant
  • 11 Answers
SOURCE: norlake 6x6 freezer compressor
No probably just frozen up due to door being left open turn unit off and check internal unit have a look on the evaporator (internal unit) see if it has a covering of ice if so leave of utill completly frost free and then restart I bet it will work
Posted on Sep 09, 2009
Handle on the freezer door has fallen off maytag model mf12568aes serial 12384967lp
If handle is right behind gaskets then pull gasket a little and you should be able to get it
Dec 12, 2017 | Refrigerators
Freezer won't shut off
Hi John,
The symptoms do indicate a failed thermostat.
I am not sure where you could get a thermostat for this freezer but I would try contacting Norlake first. They may guide you to who has one or maybe they can sell you one. If it is a direct replacement it is something that you can do yourself.
http://www.norlake.com/
May 09, 2010 | Nor-Lake Freezer Norlake Refrigeration 6'...
What should the freezer temperature shouls be????????????????
Normally, freezers are at 0 degrees. If you have ice cream, shoot for -10 degrees.
hope this is what you are looking for.
Feb 21, 2010 | Nor-Lake Freezer Norlake Refrigeration 6'...
Norlake freezer 6x6 not freezing enough
Normally freezers are kept at zero. Most health departments will not allow the temp to be higher than plus 10. If you want to store ice cream, you need to be at minus 10 degrees to minus 15 degrees.
let me know if I can be of any further help.
Sep 29, 2009 | Nor-Lake Freezer Norlake Refrigeration 6'...
Norlake 6x6 freezer compressor
Sep 09, 2009 | Refrigerators
Need to know breaker and wire size to run from panel
Compressor 12/3 with 20 amp dual pole breaker. 220 VAC
Freezer 12/3 with 20 amp single pole breaker 120 VAC
May 24, 2009 | Nor-Lake Freezer Walk In Freezer 6ft x...
How do turn the temp up on a norlake walkin?
They are usually mounted on the front panel of the evaporator or mounted on the wall behind the evaporator.There is a possibility that the temp. control is at the condenser,and the sensing bulb was slipped thru the wall.Look for the bulb at the back of the evaporator and follow the cap tube.
Dec 05, 2007 | Nor-Lake Freezer Norlake Refrigeration 6'...
Refrigerators Logo
24 people viewed this question
Top Nor-Lake Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Marat Brikov
Are you a Nor-Lake Refrigerator Expert? Answer questions, earn points and help others
