Dont look any further. Send it to Citizen: Full particulars can be found here: http://www.citizenwatch.com/
SOURCE: Describe your Citizen Skyhawk Eco-Drive
Here is how to correct the 0 Position for your watch.
While your the crown of your watch is down in the starting position , turn the crown until the mode hand (this is the circle at the bottom of the face) reaches CHR
At this time now pull out the crown until it clicks two times, two the second setting of the crown.
This will bring the watch to the 0 position correction function.
you can turn the crown clock wise to correct the hour hand.
press the a button to switch hand to second, or press again to switch to minute. Then use crown again to correct 0 position.
The hour and the 24 hour hand is in conjunction with each other.
then push down the crown all the way in and you should be all set.
Testimonial: "Thanks much, that's great help, solution proposed totally worked. I have this watch for about 8 years now and never once able to fix this 0 correction"
