SOURCE: Having problems mounting ceiling plate
Dear Sir/madam,
Click this link for instruction manual....check out....
http://www.belowcostappliances.com/info/fans/owners-manuals/wet-light/light-fixture.html
thanks
good luck
SOURCE: Replacing old fan with Hunter 20763.
People find all kinds of creative ways to wire things. White wires are always supposed to be neutrals and therefore should always go with other white wires, and colored wires should always be hot and should always go with other colored wires. If you have a voltage tester you could test to see if in fact the blue wire is actually the hot and the white is actually the neutral. (test each wire to a ground). If the previous fan was wired backwards, it would not affect the operation of the fan or lights at all. But you'd probably want to make sure the new fan was wired properly. In that case connect the white from the fan to the neutral and the black and black/white to the hot.
SOURCE: I have a hunter ceiling fan and the fan would not
That black box is a capacitor . You should be able to find a replacement at most building or lighting supply stores. Try Lowes, Home Depot.
SOURCE: need the manual for our ceiling fan, Hunter, Park
i have to fans close to each other i would like to change the code on the remote
I would check with a voltmeter if you can safely to verify power at the light socket using an adapter to a plug in it. If you can not do that, with power off you may want to make sure that the socket contacts are good and clean. Sometimes they can become tarnished badly.
