Sony KP-51HW40 51" Rear Projection Television Logo
Posted on Sep 09, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My kp51hw40 rear projection television timer/standby led flashes 6 times and pauses then 6 times over and over.tv clicks like it comes on but no picture or sound.
Anonymous
Level 3:
  • Master 1,476 Answers
  • Posted on Sep 09, 2011
Anonymous
Master
Level 3:
Answers
1476
Questions
0
Helped
340425
Points
4062
See my tip at http://www.fixya.com/support/r7808378-sony_tv_error_code_six_blinks for help.
Thanks for using FixYa and for the great rating.
hardrocko
1helpful
Hello, my Sony wega KDF-60WF655 tv will not turn on. The power/standby led flashes 6 times and pauses then repeats. what is the problem with tv?
This error code is an indication of a b+ error voltage ... specifically a voltage of 6 volts known as dd voltage when the voltage is low pin 129 of micro
3helpful
Sony kp-51ws520 when turned on just has standby light flashing . the rest is all dead, no picture or voice.
Standby flashing light shows that tv got some internal problem. How many times standby light is flashing is info that provide info about what section of tv got problem.
Count standby light blinks and let me know, there would be 3 seconds long pause in blinks so count pause to pause.
1helpful
2answers
I have a 56' that wont show picture
Power board is bad.. I had the same issue.
3helpful
Power/standby led beeps red light 6 times
crazyford359
Your Thermal fuse is out. I just replaced mine, the part is only $4.85 on Sonyparts.com. Ordered (2)
I have a 56" samsung rear projection tv that won't turn on. the red standby light is lit and when i push the power i hear two clicks and the green timer light flashes quickly then the green led stays lit...
I suspect you probably have a bad LED assembly. It could be either the red, green or blue that is bad and give you the same symptom. The problem is locating parts for it as it looks like the light engine is no longer available. I would have a technician look at the TV to verify this and what parts are needed for repair.
2answers
Sony Rear Projection TV - KP-46WT500 Screen went blank
When Sony TV gets problem it goes to standby as protection mode and LED start flashing.
Do you see standby light blinking?
There would be 3 seconds interval between blinks so count from pause to pause and let me know.
Thanks.
Red light flash timer stand by
Please count standby light blinks and let me know.
There would be pause of 3 seconds in blinks.
Also confirm is it Sony KP-57HW40 model?
Sony kp51hw40 projection tv screen turns blue
The blue CRT needs replacement. You can get a replacement CRT at the following link.
http://servicemanuals.vstore.ca/
3helpful
5answers
Sony KP-53V80 is not turning on.
4 LED flashes indicated a faulty IC board
Sony KP-57WS500 57 in. Rear Projection Television
THE LED ON THE FRONT OF THE SET SHOULD BE BLINKING IN A SERIES OF BLINKS THEN PAUSE AND REPEAT THE SEQUENCE. IN ANY CASE IT NEEDS TO BE SERVICED BY A SONY AUTHORIZED SERVICER.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
